Suspension Pulls to the right...
Old 06-12-2007, 05:01 PM
SORMINI's Avatar
SORMINI
SORMINI is offline
We just had the MCS in to have an alignment done. They said that the right tierod was seized, and since they didn't have a part to fix it if it broke, they didn't adjust that side. They only adjusted the left side. They stated that the left tierod was all the way out (?). We now have a pretty noticable pull to the right and we have a slight wobble at speeds between 45 and 55mph. It was in to the tire shop today to check balance, and all are perfect. We took it back to the dealer that did the alignment today(BMW), and they "looked" at it and said that it is fine and they couldn't (wouldn't) do anything else. The steering wheel sits off center when the wheels are straight now also and my hubby says that there is a warning light that keeps showing up. Something about not being centered.
Would excessive toe on one side cause pulling? I really don't understand all of the variables here.
Here's the kicker. They printed off the numbers for us, and it shows that they adjusted the front right toe, and that it is the same as the toe on the left side. This isn't possible if they didn't touch the right tierod, right?
We are sending it to another alignment shop tomorrow(not another dealer) and we will get readings and hopefully a proper alignment. Am I wrong in thinking that this dealer is screwed up?? We paid them a lot to screw up the alignment on this car. We had no issues before, but wanted to be sure because he lowered it and put on different size wheels.
EDIT: I guess there isn't a light yet, but he was told that it could throw codes if it stays out of center.
Old 06-14-2007, 01:59 AM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
see
http://www.drivewire.com/replacementparts/tierod.html
I would get the part(s) to replace the seized or worn tie rod end/assembly.
then do a full alignment to specs.
I have only a brake and alignment specialty shop do the alignment, not the dealership.
They gave you some conflicting information, doesn't add up.
Old 10-08-2010, 07:58 PM
eric loe's Avatar
eric loe
eric loe is offline
Went to get my allignment done today at firestone. The car is still pulling to the right after that. Reason is because Mini's factory camber and caster settings on the front is designed for european road which is mostly flat not curved like in US. They suggest a solution of getting a camber and caster kit so the front camber and caster can be adjusted. I know Alta PSRS allows additional caster angle. Will that fix my problem,since I will be soon due for front bushing replacement.
Old 10-09-2010, 05:58 AM
Crashton's Avatar
Crashton
Crashton is offline
Did they manage to tell you this with a straight face? What you need is a competent alignment shop.
Old 10-12-2010, 09:30 PM
Norcal_Cyclist's Avatar
Norcal_Cyclist
Norcal_Cyclist is offline
Try to cross rotate the two front tires... please post your camber toe and caster numbers and I'll help out. The roads here ARE crowned more than in Europe, cars will drift right on occasion but you should never feel a tug on the wheel. The difference in caster left to right will cause the pull not the overall numbers.
Old 10-13-2010, 06:47 AM
nitrogen76's Avatar
nitrogen76
nitrogen76 is offline
Do you have any strut tower mushrooming?
Old 10-22-2010, 12:51 PM
eric loe's Avatar
eric loe
eric loe is offline
Sorry for the late response. This site was unsafe for some time.
@Norcal Cyclist
Front Left
Camber -0.6 (actual) deg
Caster 3.8(actual) deg
Toe 0.13 (actual) 0.31 (before)
Front Right
Camber -0.7 (actual)
Caster 3.5 (actual)
Toe 0.15 (actual)
Rear Left
Camber -1.5 (actual)
Toe 0.17 (actual)
Rear Right
Camber -1.6
Toe 0.19
There is definitely no tug on steering. The car will eventually drift to the right when steering wheel is released.
@nitrogen 76
No i don't have strut mushrooming.
Thanks for the response
gnhovis
12-14-2015 05:31 PM
navybsn
10-04-2015 03:27 PM
dutchhome
09-30-2015 07:17 AM
Huskyfan
GP Talk
09-28-2015 06:08 PM
EVMini
09-28-2015 10:20 AM
Quick Reply: Suspension Pulls to the right...
