Cooper (non S) Modifications specific to the MINI Cooper (R56).
MC (Non S) - What can be done to increase HP?
Old 09-18-2007, 12:38 AM
MINI MANIAC's Avatar
MINI MANIAC
MINI MANIAC is offline
Can anyone explain to me what is ment by Flash. I have a 2007 MC (Non S) and would love to increase HP. What can be done on the inexpensive side? I search & search and can't find modifications or add-ons without spending a fortune.
Old 09-18-2007, 11:07 AM
lotsie's Avatar
lotsie
lotsie is offline
Start with an intake, should add about 5 or so Hp. Not sure what is available for the 07s, but something should be out there.
Mark
Old 09-18-2007, 11:14 AM
gokartride's Avatar
gokartride
gokartride is offline
You might get some small gains, but not sure if it'd be worth the cost. Low-cost mods would likely add very little. It might be more fun to dial in the suspension (R50 logic) but I'd wager that'd be tricky, too, as it could go all wrong. For now...I'd say just carefully study what the tuners are up to. The ECU is still a mystery from what I can tell.
Old 09-30-2007, 06:39 AM
wimsaab's Avatar
wimsaab
wimsaab is offline
There are some performance mods released!!
If you like to add some HP, go with K&N Apollo kit intake, it's claim about 8hp increase and the price is about 270$
The exhasut, supersprint-Hamann-Mini delta has released for R56 cooper non s...
The header, Hamman and Supersprint release, but the price is very high ..
I think, if you do Header,cat-back,intake and ECU, R56 cooper could gain about 30 hp +/- .... Yes....FUN.....
Old 09-30-2007, 06:44 AM
wimsaab's Avatar
wimsaab
wimsaab is offline
Exhasut Mini delta and Hamann
Attached Thumbnails MC (Non S) - What can be done to increase HP?-20070417_333558.jpg   MC (Non S) - What can be done to increase HP?-ca0002-a.jpg   MC (Non S) - What can be done to increase HP?-esd-mini-cooper-r56_1rohr.jpg
Old 09-30-2007, 06:46 AM
wimsaab's Avatar
wimsaab
wimsaab is offline
Here is Supersprint, I suggest you to use it, Great sound and look!!!!! It's design to increase torque////
Attached Thumbnails MC (Non S) - What can be done to increase HP?-d3afc901.jpg   MC (Non S) - What can be done to increase HP?-b7b89719.bmp
Old 09-30-2007, 06:48 AM
wimsaab's Avatar
wimsaab
wimsaab is offline
But if you do only two mods like Intake and Cat-back, you can gain about 10-13 HP +/- and about 5-8 nm of torque....
Old 09-30-2007, 07:09 AM
Yucca Patrol's Avatar
Yucca Patrol
Yucca Patrol is offline
My general opinion is that Cooper owners get the most gains from handling improvements rather than power increasing improvements.
Make the car handle so well that you can use your momentum rather than horsepower to stay in front!
Old 09-30-2007, 07:32 AM
snid's Avatar
snid
snid is offline
Even in an MCS, you'll get more out of handling improvements than power improvements, IMHO.
My new 2007 MCS is completely stock. It has enough torque to spin the stock runflats in first, second, and third gears (on a track, not a public street). Why add more power? It needs grip much more than power.
On my 2003 Cooper, I did a Borla exhaust. It sounds amazing, but doesn't really make the car appreciably faster. I sometimes use an Alta foam filter element in the stock airbox. I cannot tell the difference. Every time I did a suspension upgrade or wheel / tire upgrade, the difference was much more obvious.
If you're stop light racing, you're in the wrong car.
Tires make the biggest difference. BF-Goodrich g-force sports are good and cheap. Gooyear Eagle F1 GS-D3 are better. Bridgeston RE-01-R are very good. If it's a weekend only car, Falken Azenis or Hankook RS2 z212 are cheap and really grippy (but don't last very long). If it's a track / autocross only car... R-compounds make more of a difference than probably anything else you can do to the car.
If you're autocrossing or on a track, get camber plates, a mid-sized rear swaybar, springs and dampers that work well together (I went with the JCW suspension) and you'll be in heaven.
Old 09-30-2007, 08:31 AM
justintime's Avatar
justintime
justintime is offline
I'd have someone custom make some cams and do the head for you. DOHC ftw
Old 09-30-2007, 08:32 AM
justintime's Avatar
justintime
I wonder if the new MC motor would work with say a ZC head?
Old 09-30-2007, 09:06 AM
welshmenwillnotyield's Avatar
welshmenwillnotyield is offline
I have both an MC and an MCS, and both are pretty well modded, not terribly, but certainly no longer to stock specs. That said, I have found that taking some driver's schools has considerably helped the performance of my cars and me...maybe even more than the mods I did.
Old 10-20-2007, 06:28 AM
crpagan's Avatar
crpagan
crpagan is offline
I have a 2007 non s and am looking to get a exhaust and intake. What are the prices of those exhaust that where mentioned. I am holding off on wheel and handling improvements due to the winter coming.
Old 10-20-2007, 03:53 PM
Crazy_Surfer's Avatar
Crazy_Surfer
Crazy_Surfer is offline
And maybe someone could also post some links to check on the tech specs. The mentioned Supersprint Exhaust is not available for non S Mini!!!
As so many more Mods will only be available for MCS Owners. I just hope that that will change soon.
Old 10-26-2007, 12:32 PM
lacning74's Avatar
lacning74
lacning74 is offline
Anyone tried any of these mods? I'm hoping to get a little more power at highway speeds.
Old 11-03-2007, 03:10 PM
blue_bomber's Avatar
blue_bomber
blue_bomber is offline
top right of the page is a SEARCH BUTTON!!!
use it
not being an ***. but everything being asked here, has been answered time and time again. you will get more information from searching the forum than from the replys in this one thread.
Old 11-03-2007, 05:18 PM
lacning74's Avatar
lacning74
use it
I think most of us who use forums do use the search function. I haven't been able to find any posts of anyone reporting their results with non-S R56 horsepower mods. I have read extensively about such mods in older minis though. In fact, most available mods for non-S R56 coopers are just coming out.
Old 12-05-2007, 05:55 AM
wrxgoose's Avatar
wrxgoose
wrxgoose is offline
i'm hoping to find some things, but before i put anything on the car, i'm going to dyno it. get a baseline for the 2007 MC
Old 12-05-2007, 07:00 AM
lacning74's Avatar
lacning74
Awesome! Can't wait to see the results. We gotta get the 2007 MC crew psyched up. I'm sick of living vicariously through the MCS crowd.
Old 12-07-2007, 06:52 AM
wimsaab's Avatar
wimsaab
wimsaab is offline
Supersprint exhaust is avaliable for non s R56.............
www.supersprint.com
or you can search at google video, there is one person in italy has it.... nice sound....
Old 01-24-2008, 10:15 AM
lacning74's Avatar
lacning74
Anyone done anything yet with their MC? I'm waiting until Spring to get the K&N Apollo intake. Not sure how much longer I can, though.
Old 02-04-2008, 09:49 PM
laceywa's Avatar
laceywa
laceywa is offline
K&N 57i - Gen II
Any 2007 Mini (Non-S) installed K&N 57i - Gen II? Worth the money?
Old 02-05-2008, 06:47 AM
lacning74's Avatar
lacning74
x2
Old 02-16-2008, 08:44 PM
checkercoop's Avatar
checkercoop
checkercoop is offline
X3
Old 02-23-2008, 11:06 AM
minisystema's Avatar
minisystema
minisystema is offline
Just added Megan Racing exhaust, K&N Typhoon HAI, Kingsborne plugs and am pleased with the little extra torque over stock. Suspension is stock sports package with Hotchkis Comp rear sway bar. Of all the mods, the sway bar has the most instantaneous and dramatic effect (middle setting).
Best,
T.
Quick Reply: MC (Non S) - What can be done to increase HP?
