Front end parts diagram?
Old 02-04-2008, 02:23 PM
DME's Avatar
DME
DME is offline
I had a jousting match with a racoon earlier this year. He won - cracked my bumper cover and bashed the fog light right off its mounts. I got in there to look the other day and the fog light is toast - the mounting ears are all broken. Similarly, the plastic (?) that those ears mounted to - the assembly to which the fog light was screwed - is all smashed up too.
Does anyone have an exploded parts diagram of that area so I can figure out what I need to replace?
Thank you
Dave
'04 MCS EB/W 62,000 miles
Old 02-04-2008, 03:03 PM
JAGFIXER's Avatar
JAGFIXER
JAGFIXER is offline
Pelicanparts.com, have pages of parts on line. Or Haynes manual $25 Amazon.com!
Old 02-04-2008, 03:06 PM
xsmini's Avatar
xsmini
xsmini is offline
www.realoem.com works great!
Nik
Old 02-04-2008, 03:15 PM
planeguy's Avatar
planeguy
planeguy is offline
I had the same thing happed a few years ago....you are looking at the radiator support to be replaced....best price I found was rockauto.com bout $125 back then....check out realoem.com for the diagram...Its not hard to replace but you will have to remove the radiator, I was able to replace it without opening the ac condenser, thereby keeping the AC system sealed.
Old 02-04-2008, 03:30 PM
DME's Avatar
DME
DME is offline
Dammit, this is a stupid design I just was poring over this picture trying to figure out why it would be ONE HUGE PIECE and then saw your post.
What a pain in the *** for one fog light. I need someone to back into me and pay for this
Thanks for all the info,
Dave
Old 02-04-2008, 06:11 PM
nilo's Avatar
nilo
nilo is offline
I had the exact same thing happen to my Mini. I hit a possum and broke my left foglight completely off. Luckily though, only one support broke. The other two were intact (The foglight housing broke in pieces still attached to the other two support ears). Stupid desgin really. I flirted with the idea of replacing that whole plastic support but instead just bought a new foglight, attached it to the 2 remaining supports, and called it a day. Looks good as new.
Old 02-01-2014, 08:23 AM
riverrat's Avatar
riverrat
riverrat is offline
Mine got hit by a big piece of metal thrown up by an eighteen-wheeler. The top two supports were broken. I was able to glue them back on with some additional small plastic bits added to the back side. Installed a new foglight and was good to go.
Wohnson89
06-10-2020 04:53 AM
silence2-38554
11-12-2015 09:39 AM
David.R53
09-01-2015 06:51 PM
FatherG
11
08-07-2015 07:49 PM
Quick Reply: Front end parts diagram?
