"Service Engine Soon" Light On -- Reset?
Old 04-04-2008, 04:15 PM
dbsanford's Avatar
dbsanford
dbsanford is offline
I had a dealer Inspection 1 service a couple of weeks ago and now I have the "Service Engine Soon" light on. Is this something the dealer forgot to reset? If others have had that happen, can you/did you reset the light? I live over an hour from the dealer and would like to avoid a trip back. Thanks.
Old 04-04-2008, 08:38 PM
Ancient Mariner's Avatar
Ancient Mariner
Ancient Mariner is offline
Hie thee to a shop and get the code read. Or if there are any parts stores over on the right coast (o'Rielly's?) that will do it for free, use them.
The two (dealer service --> SES light) may not be related. Safe beats sorry every time.
-skip-
Old 04-05-2008, 03:25 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
Big-Daddy-Blue is offline
You can go to Autozone and have the code pulled for free and they will pull there little book out and tell you what it is.
If you need help, post the code here and plenty will chime in with a fix.
Old 04-05-2008, 03:57 PM
dbsanford's Avatar
dbsanford
Thanks Big-Daddy-Blue. I've got one nearby and will go over tomorrow.
Old 04-07-2008, 01:53 PM
SharoSC02's Avatar
SharoSC02
SharoSC02 is offline
my code indicates 0456, a vacuum leak that not even Dinan could figure out where it is coming from. Dinan told me to change the canister pump that is located by/behind the exhaust pipe next to the rear passenger wheel.
It turned out that the problem wasn't fixed. So after almost 1 week of Dinan doing a smoke test and undoing the top mount of the engine to check for any leaks and tightening all the hoses, the problem is still not fixed.
I am dumb founded right now and have no idea what to do since I can't even register the car since my registration is expired and can't even smog it with that SES light on.
Can anyone lend a helping suggestion or a remedy?
09R56
11-16-2022 10:49 AM
W0TM8
12-19-2019 07:50 AM
Drivetrain Products
08-14-2015 01:45 PM
oldkid6
08-11-2015 08:13 PM
08-07-2015 08:02 AM
Quick Reply: "Service Engine Soon" Light On -- Reset?
