Intermittent P0442
Old 06-02-2008, 08:19 PM
67/327's Avatar
67/327
67/327 is offline
Intermittent P0442
This has been intermittent since Dec. and I have to fix it for inspection.
Little or no internet information on any good Mini Fix.
This is what I've done so far:
Replaced the tank vent valve.
Made an additional gas cap gasket from gasket material for solid seal.
Removed extra gasket and greased gas cap o-ring gasket
Checked all plastic lines and connections for leaks
Removed leak detection pump with canister and examined for cracks
Cleaned pump filter
Reinstalled unit and cleared error; started engine: pump started up and ran for several minutes. Started to check plastic lines in engine compartment and pump started up again. Error 0442 was set. It didn't appear to be anything I did in engine bay. Reset error and it didn't come back, but it will.
I have AutoEnginuity laptop scan for Mini & BMW but it hasen't helped.
Parts are real expensive so I haven't mass swapped. Little old pump air filter was $60 and not stocked. A Delphi part made in Canada. I use a air compressor to clean it.
I have the Bentley manual, and it's not a complicated assy. I need to isolate the problem or if there's a known fix.
Thanks for any help.
JWC w/400 inj and other M7 upgrades.
Old 06-02-2008, 10:12 PM
Ancient Mariner's Avatar
Ancient Mariner
Ancient Mariner is offline
Good news/bad news:
Had the same problem and fought with it for months. Dealer no help, so I did some diagnostic thinking. Other than the gas cap (which I changed -no joy), there are really only two components that effect the system. The fuel tank vent valve on the right side of the engine and the diagnostic leak detection pump under the right rear fender liner.
Like you, I pulled them off and looked for cracks, etc. Nuthin'. So I pulled both and capped off the various connections. When I applied vacuum with my pump, it wouldn't hold. Leaked down from 10 in. of vac to 0 in a matter of seconds. The valve leaked down a little slower than the pump, but not by much.
Kept trying it, while using a stethescope to listen for leakage, and -whaddaya know?- both were leaking where the electrical connector plugged into the units.
Used a dremel tool to 'disassemble' the valve and discovered that the connection inside the unit is sealed by a pretty cheesy O ring, or not sealed in this case. When assembled, part of the inner housing is supposed to press against the little O ring and seal the unit vacuum tight.
The valve has to be cut open at the top where it is sealed (easy to see) with an X-acto knife and a dremel, but the pump has a snap on cap that can be pried off with a couple of very small screwdrivers.
Coated the O rings with dielectric grease. It was a pain in the a$$, but since it worked I don't care.
Reassembled the valve using a good epoxy. Snapped the cap back on the pump. This was a couple of months ago, and the problem has not returned.
Hope this helps.
jmjgarrity (02-07-2020)
Old 06-03-2008, 08:52 AM
67/327's Avatar
67/327
67/327 is offline
I used a vac tool to check the fuel vent tank valve and saw some leakage. Bought a new one for $36 (Delphi part) and the Vac held. Still had the error. Yesterday pulled the assy out of the rear tirewell. I started to take the top off the pump, saw the blue o-ring and 2 or 3 springs and was afraid to go any further least I ruin the pump. Based on your experience, I'll go back and grease the o-ring. I didn't want to buy a new pump if it still worked but I was getting desperate.
Thank you mucho! for your help . It's the first good solution I've come across.
Old 06-03-2008, 10:48 AM
Ancient Mariner
The pump is hard to damage. Don't worry too much about hurting it, it's a very simple unit. There are actually two o-rings; the large blue one that seals the top cap, and a (very) small blue one that seals the electrical connection. Mine was leaking at the electrical connection, although I did the 'belt and suspenders' thing and greased both. Hope this helps.
-skip-
Old 06-03-2008, 10:58 AM
67/327's Avatar
67/327
67/327 is offline
I just came back to check which end of the pump to work on. I did the top and will start the bottom. I'm not sure where that small o-ring is located. Do I open up the cap where you plug the cable wires, or is it the bottom where the pump resides. I don't want to pull any internal wires loose. The bottom half of the pump is proving to be a bear to unhook, how do you release all the retaining clips. I'll wait for your reply, Thanks.
I had to put it back together but before I reassembled it, I checked the vac nipple and it held at 21 in. Hg; knocked it around and it was stable, then ever so slowly started to bleed off. Later, drove it around and no error yet.
Old 06-04-2008, 09:21 AM
67/327's Avatar
67/327
67/327 is offline
If possible, would the Ancient Mariner give me a little more information on accessing the small o-ring. If I have to split the lower half of the pump, just how did you keep all the retaining hooks back far enough to break it apart. Or should I be accessing the smaller electrical compartment where the plug is inserted. Also, do think there might be a relay in that housing. Thanks.
Old 06-04-2008, 11:15 PM
Ancient Mariner
Sorry, been away.
I'll do the best I can from memory, so bear with me.
The disassembly was a pain -a few small screwdrivers to pry the clips down while at the same time pulling up on the cap to keep them from locking back again. I clamped the pump in a vise to hold it while I did it. Took three or four tries. If memory serves, everything is accesable once the top is off. Take your time with it, and keep track of where everything goes.
I honestly don't remember any complications once I got it apart, although getting the little o-ring to go back after I greased it was a little frustrating. That stuff (dielectric grease) is slippery, and the o-ring would try to climb back up out of it's seat. Tweezers did the trick.
Don't remember any relay inside the housing itself. Just the pump unit.
The whole unit is pretty simple
Old 06-05-2008, 09:09 AM
67/327's Avatar
67/327
67/327 is offline
I can see that your a busy contact on this form. That was just the information I needed. I had 4 small screwdrivers that kept popping out and decided there had to be another way; some type of shim to slip in the slot. Since the vac stayed pretty steady, I put the assy back and the check hasn't returned yet. I'll have another go at it if the error returns.
Thanks again.
TW
Old 06-06-2008, 10:45 PM
Ancient Mariner
Sweet! Glad to see that problem solved (fingers crossed). It just irks the bejeebers out of me that the dealers want only to replace the whole unit for something so simple.
Old 03-02-2009, 09:08 AM
second to none's Avatar
second to none
second to none is offline
I am reviving this old thread, with the p0442 code on my 04 MCS. I have disassembled the pump, and lubed the top and bottom o-rings with gasket seal. I will vacuum test it before I put it back in, after giving it some time to seal up. Full pics from start to end will be posted.
Old 03-05-2009, 06:22 AM
zoran's Avatar
zoran
zoran is offline
I'm having the same problem. Any pics would be appreciated.
Thanks.
Old 03-05-2009, 11:51 AM
second to none
I figured i'd try what has worked, and although my pump holds vacuum, I still have the leak. I believe it is time for a smoke test of the fuel system. Anything I find, I will post up.
Old 03-05-2009, 03:57 PM
frenchie's Avatar
frenchie
frenchie is offline
Be careful with the smoke test, I believe its recommended to use nitrogen to pressurize the system so as not to create an oxygen rich environment; else sparks from the fuel pump could make the vehicle explode!
Old 03-07-2009, 10:28 PM
Ancient Mariner
Don't forget the fuel tank vent valve under the hood if the pump fix doesn't solve the problem. It will probably be easier to buy a new one than to cut apart the old one and grease it up.
Old 04-06-2009, 12:02 PM
second to none
I have found my leak to be the gaskets around the fuel pump/fuel filter which I replaced in june of 08. I got the code two months later, and never suspected this repair to be my issue. After pulling the rear seat, the top of my tank seemed moist. One of my gaskets on the fuel pump side was kinked, causing my vapor leak. After replacing the seals with new ones (and lubed them this time with vaseline) I have had zero issues, and passed my NY inspection. I never even thought to lube them the first time, as I was stuck roadside in Georgia and needed to get running after my fuel pump was clogged, leaving me stranded otherwise. Note for the future: if you get this code, check parts of the fuel system you have/had serviced, even if it was so long ago you initially rule it out.
Old 04-22-2011, 06:46 AM
agy2k2's Avatar
agy2k2
agy2k2 is offline
I am also getting a P0442 code.
I already replaced the vent valve and had no luck.
I took the pump out and greased the 2 o-rings mentioned, but I could not get the pump to split apart in the middle. It was too hard to get apart, and I wasn't sure if there was a seal there or not.
I'll post back if this fixes my problem.
Old 11-19-2012, 03:47 PM
hoodmeister's Avatar
hoodmeister
hoodmeister is offline
Thanks Mariner. I have an '02 Cooper S and had the P0442 code for some time. State inspection being due is what got me off my butt to go after the pump. I disassembled the pump in a few ways. In the picture above you can see the tabs by the guy's thumb. I popped them lose along with the end piece (bottom of pic). Instead of contact grease, I used blue glue (Permatex Blue RTV). I ran a bead around all of the o-rings and the large diaphram. For the small 3 pin connector with the cable, I didn't want to glue it, so I did use grease there. Re-assembled, reset check engine light with my CarChip and the light has stayed off for now. Got it inspected, so I'm good for two more years in Maryland. Great post. Thanks again!!
PS. I did not cut anything with a dremel or Xacto. Just the joints that are meant to come apart.
Old 12-16-2012, 05:01 AM
kramcard6's Avatar
kramcard6
kramcard6 is offline
Can someone show me the other O Ring and also the Purge Valve? Real new to Mini and working on these cars...
Old 11-01-2014, 05:08 PM
animal1's Avatar
animal1
animal1 is offline
0442
Mini Mass has the pump on line for $117 FYI. Rock, Zone, and few others had it for $162 and MORE than mini list price! Crazy..saw it as much s $230 non OEM.
Old 06-07-2020, 11:38 AM
navwizard's Avatar
navwizard
navwizard is offline
Old thread, but big kudos to Ancient Mariner for posting this. I had a evap leak code and was about to change the fuel delivery pump. Because of this post, I checked the electrical connector, and sure enough, one of the pins wasn't sealing. You could push it down and it would pop back up.
Added some super glue and silicone to seal the pin, and problem solved! Not sure if it will last forever, but worst case is I'll have to change the pump later.
thanks!
dan
embiggenedmini
10-15-2015 12:36 PM
rustof
11
09-25-2015 10:35 AM
asmasm
09-21-2015 08:23 AM
Drivetrain Products
09-03-2015 02:06 PM
Ntety
09-02-2015 08:39 PM
Quick Reply: Intermittent P0442
