Trunk Wont Stay Closed! What gives?!
Old 10-14-2008, 12:54 AM
burley's Avatar
burley
burley is offline
I own an '03 MC and have had few problems until now. My trunk will not stay shut, even if the door is locked. I can lift the hatch open without pushing the button under the handle.
As you could imagine, this a bit of a problem since it opens a little while on the freeway as I found out the hard way.
When I push the latch button on the handle, I can hear a clicking near the latch. The locking mechanism seems isn't catching the hatch lid. Maybe its a broken spring, or maybe just a fuse or something.
Anyone have experience or suggestions?
Old 10-14-2008, 07:24 AM
Bigshot's Avatar
Bigshot
Bigshot is offline
There is a dealer warranty fix for this. They replace the catch. Check with your dealer to see if it was done.
Old 10-14-2008, 04:27 PM
burley's Avatar
burley
burley is offline
my warranty expired long ago... is this still covered?
Old 10-14-2008, 04:34 PM
D3m0N's Avatar
D3m0N
D3m0N is offline
mine I removed the boot handle cleaned the contact and WD-40'd it to repel water no problems since that
Old 10-14-2008, 05:07 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Stop calling your "boot" a trunk and it might listen
Kidding...actually I never call mine a Boot either. I think I sound silly doing that.
Old 10-14-2008, 05:19 PM
burley's Avatar
burley
burley is offline
Actually here in hawaii it'd be da-boot, brah.
Old 10-14-2008, 07:15 PM
nabeshin's Avatar
nabeshin
nabeshin is offline
Functioning Lunatic
This happened to me a while back. The solenoid was bad and I had to replace the mechanism.
Old 10-14-2008, 10:07 PM
burley's Avatar
burley
burley is offline
I took the handle apart and "cleaned" it the best I could. I didn't really see any contacts to clean. Its still wont close... Dealership quote is $200 :(
Old 10-15-2008, 12:48 PM
burley's Avatar
burley
burley is offline
Took it to Honolulu Mini... It was an emergency cable (which opens your trunk) in case of an emergency. It was broken, and stuck in the open position. I opted to leave it broken, and the analysis cost $148... At least I got a car wash and valuable time to check out the clubman.
The cable was to avoid "double locking" yourself in the car. I attempted to do so, and couldn't. Service staff said if your battery goes out, its your only way to get out of your mini. Isn't the inside door handle mechanical and not electrical? Works for me...
Old 10-15-2008, 03:11 PM
nabeshin's Avatar
nabeshin
nabeshin is offline
Functioning Lunatic
With the battery down, you can still use the door, but the window won't go down the little bit it needs to close again. Unless you bend the top of the window manually inward to acount for this gap.
On a side note, my car never came with an emergency release.
Old 10-15-2008, 09:10 PM
burley's Avatar
burley
burley is offline
yeah... I keep testing the "double lock"... I cant see how the hell you can lock yourself in a mini in an emergency. I think the service woman didn;t know what she was talking about. I almost let them charge me 350 to fix it, rather than 148 to figure out the problem and move the "broken" safety wire".
Filmy
Navigation & Audio
15
06-06-2023 06:27 AM
1chaos52
09-21-2015 05:42 AM
MiniUnz
09-14-2015 11:11 AM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
09-10-2015 12:34 PM
Dieseldoctor
R55 :: Clubman Talk (2008+)
09-09-2015 01:17 PM
Quick Reply: Trunk Wont Stay Closed! What gives?!
