Drivetrain Looking to make my MINI go fast! Ideas?
Old 05-04-2009, 06:41 PM
Mini05_Baker's Avatar
Mini05_Baker
Mini05_Baker is offline
I have a 2005 Mini cooper s. I don't really have any mods except for Milltek Exhaust. I want to make it quicker than it is, but i am lookin to spend about 1500. Can you guys give me some ideas in what to look for. the upsides and downsides. if you want you can post your specs with upgrades too. Please help!! thanks a lot
Steve
Old 05-04-2009, 06:48 PM
Intense's Avatar
Intense
Intense is offline
252whp 200trq RMW style
Reduced supercharger pulley $100
Cam $350
380 injectors (or larger) $350
Custom Dyno tune $350
Total cost $1,150 Should get you into the 200+ wheel hp territory
With the extra money you could get yourself a shiny cold air intake!
Old 05-04-2009, 07:07 PM
mininuke's Avatar
mininuke
mininuke is offline
Cam $350
Pretty accurate but don't forget the pulley removal tool from $80.00 (I have one used only once, $60 shipped) You may need a 635 Napa belt around $25. Also, depending on who does the cam and injector install it could be in the hundreds $$ for labor.
I think Mike at Mynes Performance can do a Newman cam, 550cc injectors and a tune for around $1,200.00 including labor. Mike correct me if I'm wrong here.
I'm pretty happy with my tune and parts. My dyno numbers on a heart breaker Mustang dyno were 193.5whp. Although what matters is the delta of about 40.5whp, I would have liked to see over 200whp. Perhaps I should take my car to another kind of dyno. You know the ones that always read high!! Maybe dynojet or dynapac. Over 200whp for sure. Just my .02 cents. Good luck!
Old 05-04-2009, 07:40 PM
MiniMac2005's Avatar
MiniMac2005
MiniMac2005 is offline
try giving Way a call and see if he can do anything for you when he comes to town next month...
check out this link => https://www.northamericanmotoring.co...e-20-21-a.html
Old 05-04-2009, 07:57 PM
Mini05_Baker
I will def. give him a call. now with all of those mods, would i have to change out the computer, or just dyno tune it?
Old 05-05-2009, 07:03 AM
am0eba's Avatar
am0eba
am0eba is offline
Intense is right on with his recommendation. It looks like his pricing is based on doing some of the work yourself.
I have exactly the mods he recommends:
- Webb 15% reduction supercharger pulley
- Megamini (Hubie Fuh) V1 Cam
- Bosch 550cc injectors
- NGK Iridium plugs (heat range 7)
and a Mynes ECU tune on a dyno.
The pulley was $300 installed by Webb at a pulley party.
Everything else was done last weekend at ABF in Lake Forest, CA by Hubie and the Mynes crew for just over $1300.
My baseline (with the pulley) was 184HP (Torque was in the 160's)
Final tweaked values: 206 HP (187 TQ) at the wheels on a conservative Mustang Dyno.
Mynes is out of AZ, so that might be a fairly convenient location. You could probably get them to do the whole deal, including pulley for about the same as I paid. (I think they do a traveller's discount)
_Dave_
PS: To answer your last question: No, you don't have to swap out the ECU. They flash your existing one.
Old 05-05-2009, 09:59 AM
Mini05_Baker
Cool, i have no problem with doing some work myself, like the manual labor, just the programin i would screw up. I want to be atleast 200. That is my goal. I also have some more questions If you all don't mind. I was looking to get a header too, but all I could find was the aota header. Is there anyone out there with a dif. one? And with the 550cc injectors how is the gas mileage on that. And I wish I was closer Arizona dave! I'm all the way in Chicago. And have anyone got there mini detroit tuned??
Old 05-05-2009, 10:54 AM
TRuTH's Avatar
TRuTH
TRuTH is offline
Horsepower does not always mean faster. A good driving school will help you get faster. Also, Ditch the runflats and get some sticky tires. Just my 2 cents.
Old 05-05-2009, 11:36 AM
Mike@Mynes's Avatar
Mike@Mynes
Mike@Mynes is offline
Detroit Tuned guys are good, you can't go wrong with them
The 550cc injectors are no problems at all with fuel economy... it's all in the tuned. Most of our customers get better or the same economy with the 550's - (if not all b/c with more power, they get on it more often so the fuel economy goes down :( It's all in the tune
This thread should give you some ideas on mod path... every dyno reads different so pay closer attention to the delta and the overall graphs instead of just peak numbers. The 1st ten posts have pretty much all the info you need.
https://www.northamericanmotoring.co...-your-mcs.html
cheers.
mike
Old 05-05-2009, 11:38 AM
silversmoke06's Avatar
silversmoke06
silversmoke06 is offline
Personaly I have the RMW header and cam I like it for the midrange.
My car put down 224 on a dynapack with a mild tune,(I needed more injectors)
However, Im very happy with how it runs.
I can easly blitz to 80 without much trouble, Do you need more?
I mean though the mynes crowds dyno reads diffrent than the dynapaks
the real key is the delta between old and new. this is what your going to be feeling not the peak numbers
I encourage you to do some reading as well as keep asking questions
From my experence i would try to spend just a bit more get a header cam and a pulley with a tune to top if off.
Dont forget to hunt thru the NAM marketplace... Its in the upper left of the page for deals.
Hope this helps you some
Colin.
Old 05-05-2009, 07:55 PM
MINIGURU@WAY MOTOR WORKS's Avatar
MINIGURU@WAY MOTOR WORKS is offline
Vendor
We've got all the mods you need. Call if I can help.
WAY
317.201.8670
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old 05-05-2009, 10:53 PM
Mike@Mynes's Avatar
Mike@Mynes
WAY
317.201.8670
hey Way, you are stationed between ATL and Indianapolis? wow, busy man
Both Way and DT are very reputable companies - can't go wrong with either one...
Old 05-09-2009, 06:39 PM
myles2go's Avatar
myles2go
myles2go is offline
The Chicago MINI motoring Club has a Mod Party scheduled for June 20 an 21 with Waylen. http://chicagominiclub.com/2009/04/1...0-21/#more-887
You might want to plan on attending.
Old 05-10-2009, 03:19 AM
howsoonisnow1985's Avatar
howsoonisnow1985
howsoonisnow1985 is offline
Is that Al Jourgesen on your sig? Seen them a few times, way back in 1989 and 1990.
Old 05-10-2009, 08:07 AM
MiniMac2005
why yes it is pic is Al, quote is from the song "Let's Go". Haven't seen MINIstry recently, but I attended a few concerts in the past and I have all of their music (including With Sympathy on vinyl). I used to frequent Wax Trax when it was still around.. those were the days
Old 05-10-2009, 10:02 AM
TRuTH's Avatar
TRuTH
TRuTH is offline
WHAT!!! Wax Trax is gone. OH sad day. Are we talking about the one Denver? The web says they are still around.
Old 05-10-2009, 01:57 PM
MiniMac2005
the store in Chicago has been gone for years (the one I was referring to, didn't know it all started in Denver!)... the one where Al used to hang out at. It used to be a couple of doors down from the infamous Biograph Theater. the main floor had all of the music while the upstairs had t-shirts and other stuff. It was a brisk walk from the Diversey stop on the Red Line... I never ran into Al there, but friends used to see him there all the time.
I didn't know there was a store in Denver... I thought the label died out years ago .. click the pic of Al to go to his own label (13th Planet)...
Last edited by MiniMac2005; 05-10-2009 at 02:02 PM. Reason: went to website.. correction...
Old 05-10-2009, 04:48 PM
Stanislaus's Avatar
Stanislaus
Stanislaus is offline
Why do I remember Wax Trax as a Wicker Park thing? They were on North Lincoln? Were you part of the Dreamerz crowd? Milk of Burgundy? Did you go to the Rubber Room?
I was there a little after Dreamerz, but I saw some of what was once good about Wicker Park.
Old 05-10-2009, 05:08 PM
silversmoke06
Off topic?
Old 05-10-2009, 05:23 PM
MiniMac2005
up through the late 80's-early 90's (omg ) it was on N. Lincoln Ave. There was a park on that corner where the skin-heads used to hang out that I had to avoid I don't remember Dreamerz... but I used to hang out near Belmont/Clark (the Alley, Restless Records, all of the vinyl stores on Clark near Diversey), especially at Medusa's when it used to be on Sheffield (wasn't 21 yet) and they still played good industrial music. When they closed the N.Lincoln store, it ended up in Wicker Park. But I never went there.
My apologies to Mini05_Baker for the hijack.... as mentioned before, give Waylen a call since he's coming out next month. I talked to him the other day and he's looking forward to the party
Stanislaus's Avatar
Stanislaus
Yes, there is no room for hipster nostalgia here. Carry on.
Old 05-11-2009, 02:39 PM
Dave.O's Avatar
Dave.O
Dave.O is offline
I have 250 whp / 210 tp on The Helix Mustang Dyno (Helix in Philly & Eksteins in NY) with the other tuner. (Cough Jan Cough) But I also respect anyone that is helping mods these cars to destroy all the Honda rice burners.
OP you can make your mini fast with whoever you choose to get your parts from. If you can install the parts yourself you will save some cash or have one of the great Nam vendors / shops do the job for you.
My Advice is do a lot of reading and searching and research and you will save time and $$$ by learning what other have done and had work or fail. Just try not to get caught up in all the "FanBoy" stuff.
I just wish everyone could learn to play in the same sandbox without kicking sand in eachothers eyes.
Happy Modding and good luck.
arf88
05-31-2016 03:07 PM
honderpilot
08-31-2015 02:53 AM
Mini'mon
08-26-2015 01:02 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
Quick Reply: Drivetrain Looking to make my MINI go fast! Ideas?
