Drivetrain NM Cold Air Intake or M7 Cold Air Intake?
Old 12-26-2009, 10:23 PM
sdoo12's Avatar
sdoo12
sdoo12 is offline
I am planing on buying a cold air intake soon for my R56 and I am having trouble deciding which one to get. I like the surface area of the M7's filter, but it still uses the stock inlet tube. I like the larger inlet tube on the NM, but I am not sure if the larger inlet tube makes up for the decreased surface area on the filter.
Old 12-26-2009, 10:33 PM
proppjones's Avatar
proppjones
proppjones is offline
DDM
I installed a DDM in MY R50 - purchased it from Detroit Tuned - good folks
I think they are all pretty similar- I like the sucking sound when i stomp on it. and with the megan cat back i can barely hear myself think.
Have fun
Old 12-27-2009, 12:15 AM
dunphyj's Avatar
dunphyj
dunphyj is offline
he's starting to sound like peter from M7 there... having a lot of surface area is a wonderful bragging right... but these aren't N/A cars... RAM air won't do a thing, and an open filter like M7s Super AGS i'm sure will work fine at speed but will probably heat soak like a **** like all other CAIs in heavy traffic...
here's a very quick breakdown of basically all intakes out there..
1) an intake on our car is basically a sound mod... it could help with power but only with all other supporting mods and a tune...and even then you're probably looking at 10-15whp...
2) there are basically two kinds... closed and open .. closed will be better in stop and go and open will give you sound you may be looking for...
JCW Stage 1 best you can do for stock look with hidden power and lower sound...
NM wonderful hardpipe and sound full intake...
ddmwork street, alta CAIs, replace the elbow and use the factory snorkel to put air under the filter...
DDMWorks Race Intake is a great closed system uses a RAM piece on the hood making hood scoop functional, retains stock airbox lower piece and modifies an all metal upper top with K&N intake....
M7 AGS-R basically like DDMWorks Race Intake but looses stock airbox and snorkel, makes a piece that sits on top of the engine making a basic sparkplug change kinda annoying, but very high on bling factor
M7 Super AGS basically the same as AGS-R but no funnel piece, open filter, and goes to the elbow piece like most the intakes out there...
Alta recently made a hardpipe to go with most any of these intakes (minuse NM which makes the whole intake....filter and turbo inlet hose)
Forge and K&N Typhoon intakes are like an Alta intake enclosed with a hose extending the stock snorkel into the air filter enclosure... relatively neat and clean in the engine bay but like stock setup limits induction from only one area... the snorkel...
Defenders of Speed (the one i have on my car now) is basically the best design out there IMHO, it has the perks of all the intakes with no downs... it's a closed system, with a cone filter enclosed, uses the Cowl induction method which is very big in racing, and basically makes the airbox a LOT bigger than stock or any other ones and uses the stock snorkel so you get air from the front of the car and the cowl, closed system with an open filter sound or use what Clint just came out with.. a small aluminium butterfly valve that will open under WOT and otherwise have a stock sound
aside from that there are lots of threads out there... i have one about DoS vs DDMWorks Race Intake...
happy motoring..
Old 12-27-2009, 03:13 PM
onefish2's Avatar
onefish2
onefish2 is offline
Dunphyj excellent write up. I recently went with went with all the NM Engineering products over ALTA due to "issues" other NAM members have mentioned here in the recent past. Here is my short review of the NM Engineering intake that was recently installed on my JCW:
https://www.northamericanmotoring.co...installed.html
And a pic:
Old 12-27-2009, 10:34 PM
sdoo12's Avatar
sdoo12
sdoo12 is offline
I have also received a M7 Oil Catch Can, as a gift, witch requires you to have a after market air intake to install it, b/c you have to remove the fresh air pipe. so it needs an after market air intake like M7's (I wonder why?). Do any of the intakes you have suggested work w/ this, or should I just return it and use that money on the intake?
Old 12-27-2009, 11:19 PM
dunphyj's Avatar
dunphyj
dunphyj is offline
option 2... relocate it... there has to be a way to do it....
Old 12-28-2009, 08:27 AM
Mini'mon's Avatar
Mini'mon
Mini'mon is offline
If you really want to install a catch can, with the DoS CAI, there's plenty of mounting space for a catch can where the stock airbox used to be. You can leave your stock air inlet tube alone, as it's needed with the DoS system.
Old 02-16-2010, 09:57 PM
ndylam's Avatar
ndylam
ndylam is offline
Ok, let's say I want to get the NM turbo inlet pipe.
Would the DOS Intake fit the turbo inlet pipe ? Would the DDM fits the turbo inlet pipe ?
Old 02-17-2010, 12:41 AM
Mini'mon's Avatar
Mini'mon
Mini'mon is offline
If you decide to go with the DoS CAI, I'd actually recommend the JCW turbo inlet tube/pipe. Its design features nice smooth walls (a dramatic improvement from the corrugated tube on the standard R56 'S') and a small flex section that helps to cushion the DoS CAI when the engine moves under acceleration.
Old 02-17-2010, 03:28 AM
ENGINE 58's Avatar
ENGINE 58
ENGINE 58 is offline
hey you still running the group buy on these
Old 02-17-2010, 05:47 AM
JamesHunt's Avatar
JamesHunt
JamesHunt is offline
Just buy it you will love it
Old 03-14-2010, 10:28 PM
duknbubs's Avatar
duknbubs
duknbubs is offline
hard pipe
so you are saying something like the alta hardpipe would NOT compliment the DOS intake due to the lack of flex in the system. I was thinking about getting the hardpipe now (w/ my alta intake) and switching to the DOS intake when i am back in the states and can order the modified bulkhead panel. sounds like i should skip on the hardpipe then if that is my plan? I only have an "S" so i dont think the JCW pipe is an option for me. thanks.
Old 03-14-2010, 10:49 PM
Mini'mon's Avatar
Mini'mon
Mini'mon is offline
If you want to go with the DoS intake, I'd avoid getting a hard pipe.
We're checking fitment of the JCW tube early next week on the R56 'S.' There is a difference in inlet diameters (JCW -vs.- 'S' Turbo), but we're optimistic that we can create a work-around to that issue.
-Clint
Old 03-14-2010, 11:15 PM
duknbubs's Avatar
duknbubs
duknbubs is offline
DOS
looking forward to it.
Old 03-14-2010, 11:32 PM
dunphyj's Avatar
dunphyj
dunphyj is offline
ah inlet hoses....
Old 05-13-2010, 08:32 AM
mellanor's Avatar
mellanor
mellanor is offline
Clint, did you ever resolve this? Is there a way to upgrade to a hard pipe (JCW or other) with the DoS CAI?
Old 05-13-2010, 09:33 AM
Mini'mon's Avatar
Mini'mon
Mini'mon is offline
Yes, even though the turbo inlet diameters are slightly different, you can run a JCW inlet pipe on a non-JCW MCS. We put out a post confirming fitment in
this thread a short time ago.
https://www.northamericanmotoring.co...7-post114.html
The 'catch' is that you should use a special mini-T-bolt clamp that DoS has sourced especially for this upgrade. I'll be adding the mini-T-bolt clamps to defendersofspeed.com by tonight.
Best,
-Clint
Old 05-13-2010, 10:10 AM
ndylam's Avatar
ndylam
ndylam is offline
Honestly, don't waste your money on the hard pipe inlet hose because you aren't gonna notice a huge different !!!
Trust Clint, he knows his products. The JCW pipe is the best candidate for the DoS intake.
Old 05-23-2010, 11:50 AM
Herman da German's Avatar
Herman da German
Herman da German is offline
Will the D.O.S. intake hook up to a Alta air inlet tube (soft one)?
Old 05-24-2010, 05:04 AM
Mini'mon's Avatar
Mini'mon
Mini'mon is offline
Yes it will.
Old 05-27-2010, 03:03 PM
tvrgeek's Avatar
tvrgeek
tvrgeek is offline
I see full setup. I am interested. I see the original fresh air snorkel is still in place. Does it provide some small amount of cool air to the intake? Where I like the nice big smooth hoses and shorter intake run, I am concerned with the potential of sucking in so much hot air from the back of the compartment.
Old 10-13-2010, 07:59 PM
tydude789's Avatar
tydude789
tydude789 is offline
Help?
Hey everyone, I'm new to the MINI scene and I don't know all the lingo, I have a 2006 MCS (non-JCW) and I'm guessing that's a R56?? Also, I'm looking at a cold air intake, I'm thinking the new Alta, because of its pretty low price. Can anyone give me some advice? Thanks.
Old 10-19-2010, 09:49 PM
dunphyj's Avatar
dunphyj
dunphyj is offline
2006 is still R53 so you'll be Supercharged not turboed... you already have a HUGE aftermarket for your car tho
Old 01-02-2011, 06:16 PM
gothmdoc's Avatar
gothmdoc
gothmdoc is offline
And a pic:
I have the NM intake as well, the sucking sound is amazing! however I am in desperate need of a tune to free up the new potential power gains.
Old 01-02-2011, 09:09 PM
onefish2's Avatar
onefish2
onefish2 is offline
That setup is long gone...
Quick Reply: Drivetrain NM Cold Air Intake or M7 Cold Air Intake?
