Where Is The Neutral Safety Switch???
Old 10-19-2010, 11:48 PM
rolfiesb's Avatar
rolfiesb
rolfiesb is offline
i have a 2005 mini cooper s automatic.
it's stuck at work because it will not start. the battery is strong, that i know for sure. its been pretty good at starting but during some days it will not start, but i am able to by putting the gear in P, shaking it, then moving it down to N, then it starts. i've done that method a few times but now this time it will not work. i'm pretty sure it's the neutral safety switch or something is lose within the starter unabling it to start.
but i would definately like to know where the neutral safety switch is so i can maybe adjust it so i can at least get the car running so i can bring it to the dealer.
any help will definately do!!!
THANKS!!!!!!
Old 10-20-2010, 02:03 AM
NightFlyR's Avatar
NightFlyR
NightFlyR is offline
I cant say for sure, but normally the switch is under the shift lever, and I have had one crack on a Toyota, once its gone it needs to be replaced
Old 10-20-2010, 02:59 AM
CRoth's Avatar
CRoth
CRoth is offline
It's located above the pan on the bulkhead side of the CVT. It's silver with a black plastic electrical connector. Torque for re-installation is 9 ft-lbs.
Old 10-20-2010, 10:56 AM
rolfiesb's Avatar
rolfiesb
rolfiesb is offline
So is it in the engine bay or inside of the car?
Old 10-20-2010, 11:32 AM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
Sounds like CRoth is saying it's in the engine bay.
Not sure, but it may be part number 1 (position switch) here:
http://www.realoem.com/bmw/showparts...63&hg=24&fg=15
Old 01-22-2011, 05:47 PM
rolfiesb's Avatar
rolfiesb
rolfiesb is offline
is it under the intake manifold box? or would i be able to see it just by looking at it? pics would most definately be appreciated.
10-01-2015 12:34 PM
10-01-2015 12:34 PM
10-01-2015 12:28 PM
10-01-2015 12:28 PM
10-01-2015 12:13 PM
Quick Reply: Where Is The Neutral Safety Switch???
