Water Pump Leak on 2008 Cooper w/56,000 Miles!
Old 11-11-2010, 11:36 AM
VelvetFoot's Avatar
VelvetFoot
VelvetFoot is offline
I noticed the other day my coolant level was low - two quarts low!
Luckily no engine overheat.
Jacked it up, took the wheel well cover out and looked around.
The water pump is leaking!
That's way too early, and the first time I had one leak on me since I started driving - and that's been a long time.
Is this a common problem?
Sadly, the car is out of warranty and without a Bentley manual (which of course doesn't exist) I don't know if I'd feed good about trying to replace it. (It has that friction wheel thing.) I've done several timing belt with water pump changes on a VW diesel, but that was with good documentation, tools, and time.
Has anyone else out there gone through this?
Could a non-dealer mechanic do this (again, the friction wheel)?
Thanks.
Old 11-11-2010, 12:59 PM
10Zero's Avatar
10Zero
10Zero is offline
56,000...nice. My 2010 sprung a water pump leak at 3500 miles. Fortunately for me is was a warranty repair.
Old 11-11-2010, 03:09 PM
glbfletc's Avatar
glbfletc
glbfletc is offline
Yes. I have a 2007 S with 41K. Noticed the low coolant and fluid on my garage floor. Took it in and, yes, it was the water pump. Thankfully, covered under warranty.
Old 11-12-2010, 08:59 AM
strobeyprobey's Avatar
strobeyprobey
strobeyprobey is offline
If you have a good dealer they may try to get you a discount from MINI since you are very close to the warranty period.
The minitechinfo.com site may have the procedure for changing the water pump (it should). But it costs $30 to find out if it does have it.
You could also ask your dealer to print it out for you, they certainly may do that. If you order the part from the dealer they probably would (Morristown MINI sent me a PDF for the bluetooth install no problem). If you get the instructions you can evaluate if you want to tear into it or take it in.
Old 11-12-2010, 09:59 AM
VelvetFoot's Avatar
VelvetFoot
Yes, getting the instructions is key.
I ordered the Ebay disk, but if it's like the BMW disk I bought some years ago, it probably won't be worth it.
Judging from what I've seen so far, the friction wheel might have to be manually disengaged before the water pump pully can be removed, but I have no idea.
Old 11-12-2010, 12:06 PM
strobeyprobey
I have the TIS at home from eBay, I am not sure if that has the water pump procedure as that is from late 2007 before the R56 was even sold.
Old 11-12-2010, 12:34 PM
VelvetFoot's Avatar
VelvetFoot
I managed to download a version as well - will try to install tonight. Am picking up a pump at the MINI dealer tonight. Big question I think is how to park the friction wheel in the non-contact position.
Old 11-13-2010, 07:25 AM
56rfixr's Avatar
56rfixr
56rfixr is offline
The friction wheel has a pull tab that allows it to be put into 'service' mode so that the water pump pulley and pump itself can be removed. it is in the lower right hand corner of the friction wheel. pull it out and there is a slit in the band that will attacht to the friction wheel
Old 11-13-2010, 02:28 PM
kat1689's Avatar
kat1689
kat1689 is offline
My water pump made it about 33,000 miles before it needed to be replaced. Good luck with your replacement, I hope it goes smoothly!
Old 11-13-2010, 04:37 PM
BOO6366's Avatar
BOO6366
BOO6366 is offline
My water pump was just replaced at 28,000 miles, as well as the timing chain tensioner and valve cover.
Old 12-22-2010, 02:14 PM
LASRGUY's Avatar
LASRGUY
LASRGUY is offline
another water pump replacement
Just had mine replaced at 35k under warranty. I had noticed dribbles on the garage floor and started getting intermittent over temp warnings. I hope the new one lasts longer because my warranty is up in April.
Old 12-22-2010, 02:50 PM
VelvetFoot's Avatar
VelvetFoot
I never updated my post. I managed to replace the pump that weekend. Very tight. I removed the entire friction wheel assembly, using a long-handle wrench, but I don't know if that was necessary; maybe just the wheel would've done it. Changing the serpentine belt was actually pretty easy. I already had the front right side on a jack stand and I used a smaller hydraulic jack to push a rubber mallet with the handle pushing on the spring loaded wheel until it locked. Very easy.
Old 12-28-2010, 09:22 PM
Headlands's Avatar
Headlands
Headlands is offline
I'm not sure if there are 3rd party water pumps available, but many OEM parts in a MINI are from cheaper manufacturers with variable quality control.
If you can get a better quality 3rd party water pump that will fit, I would do that.
TREX
11-02-2019 07:31 PM
Cereall
09-05-2019 06:05 PM
KrisMiss
01-03-2016 02:02 PM
phrza81
10-10-2015 11:37 PM
kwijmbo
08-05-2015 09:00 PM
Quick Reply: Water Pump Leak on 2008 Cooper w/56,000 Miles!
