Have to reset TPMS again and again and again...
Old 01-22-2011, 09:47 PM
AudioFormz's Avatar
AudioFormz
AudioFormz is offline
Ok. Got new wheels and tires with aftermarket TPMS. I did the reset and got confirmation that the TPMS was reset and it is active. Turn car off and when I turn it back on, it says need to reset again. If i ignore the message, everything looks good, TPMS is still active and no warning light. However, turn the car off again and back, I get the same message over and over and over...everytime I turn the car on. Anyone else have this problem? getting tired of the message and resetting the system just for it to say I need to do it again after I turn the engine off! Thanks for any help here! I do have the factory NAV if this helps and I did the reset through the display.
Old 01-23-2011, 07:28 AM
MINIdave's Avatar
MINIdave
MINIdave is offline
Are you sure you don't have a low tire?
If not, you could have a low battery in one of the wheel sensors.....
What year is your car?
Different years require different sensors - it's not one size fits all.
Old 01-23-2011, 08:00 AM
yetti96's Avatar
yetti96
yetti96 is offline
To reset the TPMS you do need to drive it a bit. I just did this yesterday after a rotation and the light came on, so I reset it and after a mile or so it went away.
Old 01-23-2011, 09:05 AM
MP1.6T's Avatar
MP1.6T
MP1.6T is offline
Per prior post, what year car?
2010 and later vehicle sensors are different part numbers than 2007-2009.
As me how I know...
Who made sensors also? If not Beru (the OEM supplier), that may be your answer as well--as in, get different sensors.
Old 01-28-2011, 09:48 PM
AudioFormz's Avatar
AudioFormz
tire pressure is 38 psi in all tires. I does take 3-4 miles to reset and make the TPMS active which I thought was a little too long. Every time I kill the ignition it says set tire pressures. However, the malfunction light does not come on. If i hit the back button and check the TPMS status, it says active. Very strange. I think its an issue with the aftermarket sensors, which I do not even know which ones I have at this time. I'll call my dealer and find out. I just find it strange that it does reset and its active but only till the ignition is turned off. My local MINI dealer is going to test the communication next week as well when they try to find out whats up with my USB connection.
Old 01-29-2011, 05:29 AM
richardsperry's Avatar
richardsperry
richardsperry is offline
As stated the 2010+ cars use a different sensor with a different frequency. The sensors are $380ish for the set vs <$200 for the older style... I got them from TireRack along with the winter wheels and snow tires, and haven't had any problems.
Thanks BMW...
Old 01-30-2011, 09:03 PM
AudioFormz's Avatar
AudioFormz
thanks for the info on the sensors. I got a call into the dealer that sold me the sensors to find out which model and brand they are. Mine is a 09 club so hopefully they didnt send one for 2010 models.
Old 03-23-2011, 05:41 PM
rrcaniglia's Avatar
rrcaniglia
rrcaniglia is offline
I am having the same or a similar issue. The horseshoe/exclamation point symbol shows up frequently. TPMS shows active and I have ensured it indicated RESET and then have driven to allow it to work, but it never seems to permanently solve the issue. Often, if I do nothing, it will turn off the warning light spontaneously while sitting still--nothing I am doing. It always goes off after a few yards of driving if I do nothing more.
I have OEM sensors.
This happened the previous time I rotated the tires. Eventually, it did reset and stayed fine for 5k miles. Now, voila! It's baaaack.
Old 03-23-2011, 06:17 PM
djDK's Avatar
djDK
djDK is offline
dang 350+ for a kit of TPMS....all new cars are beginnging to get these systems now. i think they are freaking annoying. i would rather not have it and save some money,
the usually old school push the tires with my thumb once a month always works
Old 03-24-2012, 02:31 PM
JPMM's Avatar
JPMM
JPMM is offline
ever figure out the problem?
I have OEM sensors.
Old 03-24-2012, 07:49 PM
PatM's Avatar
PatM
PatM is offline
Thanks BMW...
My local Discount Tire store is selling me the 2010+ sensors for $280.00. So look around the pricing can be competitive.
Old 03-25-2012, 04:45 AM
richardsperry
The sensors are much cheaper now than when I got them.
Old 03-25-2012, 05:50 AM
JPMM's Avatar
JPMM
JPMM is offline
looks like I'll have to get fresh ones, OEM or aftermarket?
Old 03-25-2012, 05:52 AM
drsimmons's Avatar
drsimmons
drsimmons is offline
Havent' had issues with mine since I changed wheels/tires and purchased new TPMS's but out of curiosity, if you just DON'T put them in what's the worst that can happen? You just have the TPMS light all the time?
Old 03-26-2012, 06:53 PM
JPMM's Avatar
JPMM
JPMM is offline
after about 4 resets ,now its not throwing codes
Old 03-27-2012, 05:46 PM
JPMM's Avatar
JPMM
JPMM is offline
screw it the codes came back,I'll order new TPMS tomorrow
Old 03-27-2012, 06:34 PM
teamrubixcube's Avatar
teamrubixcube
teamrubixcube is offline
On 07's with a rubber valve stem you don't need a sensor inside the tire. I am VERY VERY thankful my car qualifies. Just a sensor similar to the 1st gen MINIs. It's not as precise as the 'in-tire' sensors but gets the job done. Metal valve stems then you are out of luck
Old 04-02-2012, 09:16 PM
JPMM's Avatar
JPMM
JPMM is offline
Bought a set from Tire Rack like the ones they installed in my snow tires/wheels. They auto reset in a block and have been trouble free
freckles81
01-15-2017 06:33 AM
OldElvis
Tires, Wheels, & Brakes
10-01-2015 06:21 AM
simo711
09-29-2015 11:53 AM
PSU 98
09-11-2015 11:20 AM
renchjeep
09-06-2015 01:54 PM
Quick Reply: Have to reset TPMS again and again and again...
