CEL Code P1497 & engine stuttering at idle
Old 02-01-2011, 02:28 PM
bennyG19's Avatar
bennyG19
bennyG19 is offline
Our '07 MCS was throwing this code and stuttered BAD at idle from time to time. It would get really herky jerky cruising from light to light in town. A couple of weeks ago it wouldn't start. I thought we'd jump start it and be on our way but I was WRONG!! It would crank but never seemed to be getting gas. We bought an extended warranty so I took it to the dealer (Non-MINI).
They couldn't figure it out so they sent it off to the MINI dealer. They determined that the battery was dead :( and said it was ok after a charge. A few hours later they discovered the stutter at idle and kept investigating. A couple of days later they figured out that there was a cracked valve cover. I think they also said that they cleaned the intake valves but I'm not sure about that.
Anyway, we got the car back today and it is running better than ever. It seems like this cracked valve cover had been there since we bought it (4 months/ 3k miles ago). My moral of the story is that if you are getting a P1497 code and rough idle you might want to check the valve cover
My independent mechanic had checked it out a couple of months ago and found the 'un-metered air leak' but couldn't figure out where it was coming from. I'm hoping this solves our problems.
Old 02-02-2011, 08:43 AM
chakraj's Avatar
chakraj
chakraj is offline
Yes, that is exactly what I have. The dealer couldnt find it, I even told them it sounds like a cracked valve cover (there is a new vacuum leak sound).
I am very unhappy with mini service.
Old 09-12-2012, 10:11 AM
56_oval's Avatar
56_oval
56_oval is offline
I've been getting the same code. My cooper isn't that bad as it always starts, but the code comes back every time I turn it off and sometimes a get P2187 as well telling me something about a boost leak. Talked to a mech friend and he thinks its the cover as well, I just wish it was a $400 part since we're not %100 sure...
Old 12-22-2014, 08:52 AM
louisvuittonch's Avatar
louisvuittonch
louisvuittonch is offline
Happened to me last week. CEL on with code P1497. Having the car checked today at MINI and they claimed its the lose hose connecting the airbox to the turbo causing the issue. Does this sound promising?
R60abq
R60/R61 Stock Problems/Issues
06-06-2017 05:15 PM
mdutton11
14
10-26-2015 01:47 PM
David.R53
09-01-2015 06:49 PM
makg
08-21-2015 02:49 AM
Lt. Dan
08-10-2015 08:23 AM
Quick Reply: CEL Code P1497 & engine stuttering at idle
