Drivetrain Acorns in the intake
Old 02-10-2011, 07:01 PM
Kenneth Roehl's Avatar
Kenneth Roehl
Kenneth Roehl is offline
Took the air filter apart on my JCW and was dumfounded to find acorns under the flat filter in the bottom half of the filter box. How do those critters get in there? This was part of the R&R to install the Alta cold side silicon tube,a real tight fit. What kind of mouse trap do I need?
Old 02-10-2011, 08:19 PM
ThumperMCS's Avatar
ThumperMCS
ThumperMCS is offline
I remember the same thing happened to someone else on here too....can't remember who though
Old 02-10-2011, 08:51 PM
drewstermalloy's Avatar
drewstermalloy
drewstermalloy is offline
Maybe squirrels carried them in there??
Old 02-10-2011, 09:30 PM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
If it is rats or mice you are plagued with, go to
http://www.backwoodshome.com/articles2/easterly110.html for a great trap idea. If on the other hand, squirrels are up to no good you'll need a bigger barrel with something sticky in it instead of water. Squirrels are pretty nimble.
Old 02-13-2011, 06:23 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Seen it happen a couple times, mice are the cause.
Old 02-13-2011, 07:51 PM
dannyhavok's Avatar
dannyhavok
dannyhavok is offline
Not quite the same, but when I cracked open the airbox on my CBR600 F4, I found all sorts of weird stuff.. wasps, bumble bees, huge moths, etc. No wonder it wasn't running great!
Old 02-13-2011, 08:58 PM
dunphyj's Avatar
dunphyj
dunphyj is offline
it adds character :P
Old 02-13-2011, 09:13 PM
Melangell's Avatar
Melangell
Melangell is offline
Hunt down th' critters 'n make them pay! No quarter! Argh!
Old 02-14-2011, 05:34 AM
schatzy62's Avatar
schatzy62
schatzy62 is offline
Yeah that was me that had a real problem with them, Not mice actually it was squirrels in my case. Here is the thread with pictures.
https://www.northamericanmotoring.co...-be-wrong.html
Old 02-14-2011, 07:48 AM
ChefTyler's Avatar
ChefTyler
ChefTyler is offline
I had field mice eat the wiring of my off-road lights on my Xterra once, sprayed the engine bay with a habanero solution and it never happened again. Not an ideal solution because of the obvious residue all over the engine bay but it worked.
Old 02-15-2011, 01:32 PM
Kenneth Roehl
The solution to the chipmunks using my intake as a safe deposit box seems simple after I looked at it. I will make up a wire mesh cover for the intake at the front headlight(2009 JCW) out of 1/4" wire screen. this should let all the air in and keep the chipmunks out.Take it easy,But take it Ken R.
rtk90
08-29-2019 09:08 AM
67morris
05-07-2016 11:52 AM
09-22-2015 02:05 PM
knbond1
09-22-2015 06:20 AM
Drivetrain Products
09-11-2015 11:09 AM
Quick Reply: Drivetrain Acorns in the intake
