R50/53 Sluggish accelaration and EP error code
Old 04-28-2011, 04:45 PM
hong's Avatar
hong
hong is offline
Hi, I noticed a big sound and shake when I shifted the gear from P to D today. hmm, nothing to worry about I said to myself.
However I immediatly noticed the gear indicator is showing a "EP" instead of the usual "D/SD", and paddle shift stopped working. I also noticed it seems to stick with gear 1 or 2 and has trouble pulling the car forward at normal speed.
Oh the service light turned on too.
I guess I need to see a mechanic ASAP, I'm interested to know what's your thoughts? and if it can be a DIY job.
FYI my car is a 2006 S with paddle shift, milage is around 50k.
Hong
Old 04-28-2011, 05:39 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
-=gRaY rAvEn=- is offline
Moderator
What color is the service light ? Red or yellow ?
Red means pull over and dont drive it anymore.
Yellow is typically call for an appointment with your MINI service dept.
Sorta need to get the code for the CEL before determining if it's something you can do yourself.....
Old 04-28-2011, 09:42 PM
hong's Avatar
hong
hong is offline
thanks for your reply, luckly the light is yellow, I'll make an appointment with the service guys then.
Hong
Old 04-28-2011, 09:50 PM
hong's Avatar
hong
hong is offline
Hong
Steffen.Johnson
71
01-26-2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
11-29-2016 05:04 PM
sirfrank
09-11-2015 01:36 PM
MiniSkoon
09-09-2015 12:40 PM
MasterShaftner
09-04-2015 03:52 PM
Quick Reply: R50/53 Sluggish accelaration and EP error code
