R56 2011 mini s oil filter location????
Old 09-26-2011, 09:17 AM
rtruesdale's Avatar
rtruesdale
rtruesdale is offline
Can someone tell me where the oil filter is located on the 2011 mini s? found some youtube videos but they must have changed the location again!!
thanks
Old 09-26-2011, 09:34 AM
rhawth99's Avatar
rhawth99
rhawth99 is offline
Right under the radiator expansion tank. There is one (or two) screws holding it in place, remove these and rotate it . You will see the oil filter below.
Old 09-26-2011, 09:46 AM
rtruesdale's Avatar
rtruesdale
Is it supposed to look like this?
http://www.youtube.com/watch?v=5TCUdiHDnUg
I pulled the resevoire away but there is nothing there. I am confused on this one.
Old 09-26-2011, 10:43 AM
rtruesdale's Avatar
rtruesdale
I found it. Not directly under the radiator overflow but below and to the left. Did not have good enough light to see the first time.
Good to go. thanks!
Old 09-26-2011, 12:35 PM
cccplus's Avatar
cccplus
cccplus is offline
there's a diy post for mcs auto here under diy section. granted it's for a 2010 but the it's pretty much the same for 2011. i did mine following the post. the only difference was that the coolant reservoir tank could not be twisted and moved out of the way to get to the oil filter - it took some maneuvering to change it. good luck
Old 09-26-2011, 02:33 PM
rtruesdale's Avatar
rtruesdale
Finally found it tucked away just to the left under the overflow. Needed better light.
Sure was a @#$@#$ to take out and replace. you would think those genius engineers could make something like that easy to get to since you replace it so often.
At least i have it now. thanks
Colt45Magnus
07-14-2019 06:18 PM
minicoclub
11-11-2015 07:25 AM
minicoclub
08-25-2015 09:07 AM
ludedude
08-10-2015 07:16 PM
M7Speed
08-06-2015 01:48 PM
Quick Reply: R56 2011 mini s oil filter location????
