Drivetrain dt bpv...im a believer
Old 09-26-2011, 09:53 AM
rod from maryland's Avatar
rod from maryland
rod from maryland is offline
my mini had 137K when i bought it..after the standard run of engine mods...cai, 15% pulley and exhaust, i tried the VGS system to rid the drivability problems at low rpms....was a great improvement..thought I was a happy camper. I had already ordered a DT bpv as well, but it was just sitting in the corner of the bench ....i installed a "fun" gauge ( boost) this weekend and it only read about 10 at full load. wsnt sure if it was the gauge , or plumbing or i simply wasnt making the boost i thought i should .
so, I replaced my bpv today w the dt version....just came back from a test drive...WOW....making a full 15psi at load now. what a difference...i went back in the garage and looked at the one I pulled out...it had a gap of light around 2/3 of the circle in the closed position. So, I now know where my 5 lbs boost was going..I MAY have been able to center the valve and adjust it for full closure, and may have ended up in the same place, BUT I cant and wont complain about the cost..probably would need the valve replaced anyway with that level of mileage
thought Id share this with others > if this is old news, sorry....
didnt think adding the boost gauge would do anything other than amuse me, but in this case, it REALLY gave me a diagnostic that was valid
Old 09-26-2011, 10:14 AM
jaqattack02's Avatar
jaqattack02
jaqattack02 is offline
+1
My car wasn't driving right, and after discussing it here the community opinion was that my BPV was having issues. Ordered a DT valve, installed it this past Friday evening, and holy crap what a difference. In my case it had a gap around it, and the spring was also quite weak. It took very little effort to actuate the spring on my old one, and the DT spring was quite stiff.
Old 09-26-2011, 11:30 AM
2mD's Avatar
2mD
2mD is offline
if you adjust it to close fully it can get stuck. ( there is supposed to be a slight gap )
what probably failed was the spring ( either it was getting to weak or it simply broke )
Old 05-12-2012, 03:47 PM
Blaxin41's Avatar
Blaxin41
Blaxin41 is offline
Totally agree, just put the DT BPV on my 04 with 60k but bought a 45k. Didn't know I had a boost leak because I bought it with it. Did the BPV replacement on a recommendation and I easily got 3-5 pounds of boost back. Pulls so much harder in all gears now that I have my boost back. Best 120 bucks I ever spent.
Old 05-14-2012, 09:46 AM
banzairx7's Avatar
banzairx7
banzairx7 is offline
I put in the DT valve a few weeks ago. My stock valve was sealing just fine but the spring broke. I also had done the VG mod. There was no boost increase in my case but the increase in throttle response was very noticeable. Boost comes on much quicker and earlier in the RPM's than it did before. This is how the car should have been from the factory IMO.
Old 05-14-2012, 03:47 PM
4wheels's Avatar
4wheels
4wheels is offline
Previously I had adjusted my stock BPV to nearly fully seat so I wasn't losing any boost. That's a big part of any improvement. I tried the VGS and it worked in the beginning, but oddly enough the yo-yo started a while after I added the VGS & the computer adapted. Also some ppl report issues with the VGS & have set a MIL (error code), since the mod fools the valve into closing earlier (similar to the DT BPV). Snapping the valve shut so much earlier can result in a momentary lean spot when boost spikes & you can get knock or an over boost warning. Some Mini's do this, some don't. Probably depends on the condition of your MAP sensors & how the ECU adapts to them (yes the ECU adapts MAP sensor parameters, and throttle blade too) & which h/w s/w rev your car has.
When I upgraded to a bored & stroked engine in my Mini, I went to a DT BPV and I like it overall, but if anyone gets a MIL or experiences some odd behavior, your car may not like the sudden boost spikes.
Old 05-14-2012, 04:01 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
ClintTheMiniOwner is offline
I had to remove mine when I went with 10:1 CP pistons. Apparently its very hard to tune for in my application due to pinging.
Old 05-17-2012, 05:19 PM
scoopy's Avatar
scoopy
scoopy is offline
is there a diy link for the dt bpv? thanks
Old 05-17-2012, 11:17 PM
BlwnAway's Avatar
BlwnAway
BlwnAway is offline
Not really, just install instructions.
You could try to replace the spring & adjust the butterfly yourself, but Chad knows just which spring to use & how to do the adjustments.
And anyone who hasn't gotten one of these, don't think it's a rebuilt unit, it's a modified brand new BPV.
Old 06-30-2012, 05:30 PM
scoopy's Avatar
scoopy
scoopy is offline
what's is the stock boost if you have 17% pulley? i changed the stock ones for the dt bpv, 17% pulley, jcw injectors, and crankshaft ati damper pulley. the car feels strong but i do not know if i'm hitting the correct boost/vacuum thingy. I can use the torque application and i can see that there is a vacuum/psi/boost gauge there. How should i see my boost? eg full throttle from first to third gear? thanks
Old 07-06-2012, 08:15 AM
JumpingJackFlash's Avatar
JumpingJackFlash
JumpingJackFlash is offline
My factory BPV was just fine, but I chose to go with the VGS mod because I wanted to see how differently the valve would function when "boosted" shut vs. being "vacuumed" shut under a pressure difference. I liked the mod, but I subsequently created a yo-yo condition at low RPMs. So I opted to get the DT BPV. Was well worth it. Like banzairx7 said, boost comes on quicker and harder. Yeah, I lose 1-2 MPG, but I'm not crying about it. Heck I lose more MPG anyway due to the increased fun factor.
ian260
03-29-2017 06:08 AM
10-01-2015 12:13 PM
09-30-2015 11:39 AM
09-30-2015 11:38 AM
09-29-2015 12:11 PM
Quick Reply: Drivetrain dt bpv...im a believer
