17" Tire sizes that fit Minis
Old 11-14-2011, 05:27 AM
loansinpa's Avatar
loansinpa
loansinpa is offline
Originally Posted by Derepente
The performance might improve with an increase in tire pressure. What PSI are you running the 215-45-17 CEC DWS tires on now?
I saw an earlier post or thread with Psi higher than what's on the door label.
Right now I have them set to 35. I was thinking of taking them higher to see what kind of difference it made but just haven't gotten around to it yet.
  #27
Old 11-14-2011, 12:31 PM
jorn's Avatar
jorn
jorn is offline
I was just on TireRack and had to select custom size so that it wouldn't default to the 205-45-17 size. Jorn, your looking at 225 tires...had you run on these "shoes" before? I thought it might cause rubbing inside the wheel well of a stock suspension setup. I like the idea of more tire on the road. I've read that the wider tire might decrease cornering responsiveness...but I don't know from experience. Your thoughts?
I'm a bit of a luddite here, so your instincts might be correct. Even a 205 or 215 tire would be nice.
  #28
Old 11-19-2011, 06:00 AM
howsoonisnow1985's Avatar
howsoonisnow1985
howsoonisnow1985 is offline
Originally Posted by bluefox280
Here's the common ones:
205/40-R17
205/45-R17 (stock R56 size)
215/45-R17
225/45-R17 R56 only
225/35-R17
- Erik
Yep and 2 more prolly my fave of the selection is:
215/40-17
235/40-17 R56 only
  #29
Old 11-19-2011, 07:26 PM
Powashiftin's Avatar
Powashiftin
Powashiftin is offline
So what's the biggest tire I can fit on a R56 with stock suspension?
  #30
Old 11-20-2011, 04:23 AM
Derepente's Avatar
Derepente
Derepente is offline
Hi Powashiftin, I don't know. It seems 225/45/17 would have been the max for me, but I am very happy with the 215/45/17 ContinentalExtremeContact DWS tires I had put on by TireVan. A trip in the neighborhood immediately showed me what so many others already know: the ride is nicer than the runflats. The installed PSI was 35psi. I think I will increase that to 36 or 37. The real test will be Monday's commute. I'll travel backroads and highways over cement and pavement. Not too many twisties, but It will be a good first check. One note, I like that the tire seems flush to the rim edge. The OEM Continentals at 205/45/17 were slightly inside the rim edge. Also, these new tires fill the wheel well a little more.
  #31
Old 11-20-2011, 05:51 PM
Derepente's Avatar
Derepente
Day 2 on the 215/45 ContiS. Had the whole family in the car. Everyone agreed the ride is nicer. On some 25 to 30 mph curves, I noticed what others have said. My car has some give in the corners. It still feels like it takes corners on rails...but more like when you ride a wooden roller coaster and the car sways just a bit. I'm probably making too much of it.
Nice thing though about the bumps and imperfections in the road. They are much easier to take. Not sure if this is all due to the non-runflat phenomenon only or if the added size has a large or small factor to this.
One note: Today's trips were done on 36 PSI. I increased each tire by a pound since yesterday since the ride seemed way too soft.
  #32
Old 11-20-2011, 06:32 PM
Powashiftin
Great review. Thanks
Anyone know if I can fit a 225/45/17 tire on a stock R56?
  #33
Old 11-21-2011, 01:39 AM
howsoonisnow1985
I'd rather go 235/40-17 Not sure of the rather tall size or 225/45-17???
https://www.northamericanmotoring.co...377-post8.html
https://www.northamericanmotoring.co...86-post28.html
  #34
Old 11-21-2011, 04:21 AM
Powashiftin
What about on stock rims
  #35
Old 11-22-2011, 02:23 AM
howsoonisnow1985
Oh I see you got R56. It might fit, if it does not all you need is 5mm spacers. I think it will fit, just have to keep an eye on the inside rear wheel.
  #36
Old 11-22-2011, 02:50 AM
Derepente's Avatar
Derepente
Getting a not so soft non runflat tire
I like your thinking on this. I think I would have like a lower profile than the 45 that I have. The 215 width is nice, but the 45 profile is softer than I am used to...of course. I'm sure it will take time to get used to it.
Yesterday I did my commute almost twice. About 80 miles in, out, and again driving over backroads and hwy. It was wet with light rain. The ContinentalExtremeContact DWS tires did very well. In the rougher areas of road, I was glad I had nonrunflats, so much smoother than before.
But I do miss that connected feel you get from a hard tire. That's the balancing act (no pun intended, but o.k.) when you are looking for a non runflat tire: Trying to lessen the harsh ride without going too soft.
I think a 215/40 or 215/35 might be in my future.
  #37
Old 12-28-2011, 05:14 PM
Ronin82's Avatar
Ronin82
Ronin82 is offline
205/40-R17
215/45-R17
225/45-R17
225/35-R17
- Erik
I just came in from firestone with the intention of swapping my BNIB deceptions 17x7.5's 45mm and I held off after the firestone tech called me over to show me that my wheels with the 205/45 RF's WILL rubb. He showed me the marks where they already rub,... and I'm stock. your thoughts???
  #38
Old 12-28-2011, 06:24 PM
bluefox280's Avatar
bluefox280
bluefox280 is offline
So you mounted the 205/45 tore on a 7.5" wide wheel with a 45mm offset?
The width and offset are hurting you, as the OEM 7" wide wheels have a typical offset of 48mm.
The extra half-inch width without moving the offset largely enough is causing the rubbing issue.
- Erik
  #39
Old 12-28-2011, 06:41 PM
Ronin82's Avatar
Ronin82
Ronin82 is offline
- Erik
soooo.... a spacer with about how much you think???
  #40
Old 12-30-2011, 06:56 AM
bluefox280's Avatar
bluefox280
7mm - 10mm would be a good for you to clear.
- Erik
  #41
Old 05-19-2012, 10:33 AM
Torri91's Avatar
Torri91
Torri91 is offline
I too would like to know the answer to this question as well since I am about to invest in Falken RT615's in either 215-45-17 or 225-45-17 on Konig Deceptions (http://www.altaperformance.com/hardt...17-wheel-black) or Konig Feathers http://www.altaperformance.com/hardt...ather-17-wheel.
Any information would help .
  #42
Old 05-20-2012, 10:36 PM
truckboy's Avatar
truckboy
truckboy is offline
I think you should visit and consult the same with a good tire installer or tire dealer because these are the expertise on the same.
  #43
Old 05-22-2012, 06:46 AM
Alex@tirerack's Avatar
Alex@tirerack
Alex@tirerack is offline
I would not go wider than 215/45R17.
  #44
Old 05-25-2012, 08:01 AM
dboard7's Avatar
dboard7
dboard7 is offline
I'm running 215/45/17 BFG g-Force Comp 2's with Swift spec-R springs and no not have any clearance issues on the street or track
  #45
Old 08-31-2012, 05:21 AM
jbourne's Avatar
jbourne
jbourne is offline
Originally Posted by daflake
Any of the tire sizes mentioned should for without issue. I had some slight rubbing with mine but it was due to the off set of the OZ Ultralegggeras.
Where was your rubbing? I'm running 205/45R17 Ventus V12 Evo on Ultraleggeras lowered on Eibachs and do not appear to rub. Going to a set of BC Racing coilovers though... Wonder if that will cause rubbing?
  #46
Old 02-02-2014, 09:51 AM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
What do you guys reccomend for a 09' JCW?
  #47
Old 02-02-2014, 10:14 AM
HorseWithNoName's Avatar
HorseWithNoName
HorseWithNoName is offline
225 45 17 is the tire size I run on our 2011 r56's with stock rims using Bridgestone S04 poles in a non run flat. Would never go back to the little 205's ....
  #48
Old 02-03-2014, 02:27 AM
Derepente's Avatar
Derepente
225 45 17 tire size won't rub on stock suspension, that is what I have and mine are Continental DWS extreme contact. However, at 35000 miles, the tires are "cupping" I believe is the term. Due to the extra 1inch in width, the wear is uneven on the outer edge of the tread. At highway speeds, I can hear a distinct humming or "wum wum" sound from the rear tires. Technician also confirmed issue just looking at tires. PSI is 39lbs all around. I want to get rid of the wum wum sound so I am going to go with smaller width at 215 45 17 Michellan Pilot Sports AS.
  #49
Old 02-03-2014, 06:48 AM
The_Blurr's Avatar
The_Blurr
The_Blurr is offline
could this be due to an alignment issue and not so much tire size? I've also been thinking of doing 215's but since I'm going to up to a 17x7.5" wheel the 205 will give a slight "stretch" look that I want.
  #50
Old 02-03-2014, 04:50 PM
HorseWithNoName
On my forth set of 225 45 16 between two MCS’s, I have tried Bridgestone RE11, RE760 and S-04 poles (my personal favorite) with perfect cross wear and no issues of any kind.
I’m sure you stay on top of your rotations, balancing and alignments like I do, but personally I stop using Continental and Pirelli tires because they always seemed to develop some kind of odd uneven wear or performance issue in the last 25% of tire life.
I’m thinking your assessment is dead-on downsizing an all-season tire in a summer tire environment like Tampa. The all-season is likely the root issue as it is designed to be more flexible in the cold but doesn’t hold its contour in the heat, you may want to consider the Michelin Pilot Super Sport even if you decide to down size to 215’s.
Just a friendly suggestion...
Quick Reply: 17" Tire sizes that fit Minis
