R56 Carbon Cleaning - BG Fuel Air Induction Cleaning Service
Old 12-19-2012, 07:40 AM
fullymooned's Avatar
fullymooned
fullymooned is offline
Dealer says that my 2007 R56 S needs carbon cleaning due to excessive buildup in intake valves, combustion chamber, fuel injectors. He wants to charge $600+
I found a local mechanic shop nearby that does the BG Fuel Air Induction Cleaning Service and will charge $160. Youtube video linked below. Will this help?
http://youtu.be/3Bad4te5Tao
Thank you.
Old 12-19-2012, 08:48 AM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
Can't tell from the video.....seems like they would have to include the PVC system and they don't say. If it's just for the injectors, which would seem to be the typical approach, then it wouldn't do much. Not that I know much about this....just have a Clubman with 90k on it that probably needs to be cleaned.
Old 12-19-2012, 08:55 AM
fullymooned
Reading here it seems the ways are either Walnut Shells or manually cleaning on intake valves.
How to manually clean the valves. Has anyone done it?
Old 12-19-2012, 08:57 AM
countryboyshane's Avatar
countryboyshane
countryboyshane is offline
Yup, I've done it. Don't bother trying to use BG or Seafoam to try and fix the issue if the dealer says you need it that badly. Walnut blasting is the best solution but you can do a pretty good job cleaning it out by hand if you have patience.
Old 12-19-2012, 11:53 AM
fullymooned
I would rather do it on my own. Is there a DIY out there? Car has 85K miles and I think the coking is quite severe. Any ideas how to do it manually?
Old 12-19-2012, 12:02 PM
Slave to Felines's Avatar
Slave to Felines
Slave to Felines is offline
Search around here, there's been a DIY posted with pictures. You may have to go to Google and add "site:northamericanmotoring.com" to your query to find it.
Basically, you take the intake manifold off, and you go in with solvent and your choice of implements of destruction (picks, scrapers, gun barrel cleaners, brushes of all kinds) and probably a shop-vac.
Old 12-19-2012, 12:12 PM
miles_miles7's Avatar
miles_miles7
miles_miles7 is offline
someone here did a diy on walnut blasting.
good luck on doing it manually.
Old 12-19-2012, 12:13 PM
fullymooned
I dont mean to be lazy but is this the DIY you were referring to
https://www.northamericanmotoring.co...right-way.html
Old 12-19-2012, 12:27 PM
Helix13mini's Avatar
Helix13mini
Helix13mini is offline
This. Did you get a backache leaning over the engine? We charge $349 for the walnut service: I don't know where you are but the higher tech service facilities have the proper tools and charge less than dealerships.
Old 12-19-2012, 01:17 PM
fullymooned
Am in OH, where are you guys located?
Old 12-19-2012, 01:32 PM
gixxerjasen's Avatar
gixxerjasen
gixxerjasen is offline
Nice to know the smaller shops are picking up and able to do this kind of stuff.
Old 12-19-2012, 01:52 PM
Helix13mini
Philly.
ROAD TRIP!!!!
Old 12-19-2012, 02:18 PM
Bob Saget's Avatar
Bob Saget
Bob Saget is offline
Philly.
ROAD TRIP!!!!
Yup!!! I just had my '07 S done at Helix! They did an awesome job. Well worth the trip from Baltimore MD.
Old 12-19-2012, 06:13 PM
countryboyshane
Ha, my calf muscles actually get more stiff than anything. Chad @ Detroit Tuned is practically down the street from me but I don't think he's offering the service yet.
Old 12-20-2012, 07:20 AM
fullymooned
Philly.
ROAD TRIP!!!!
I may be driving down there in the summer. Will try to make it to your shop if possible. Thank you.
W0TM8
12-19-2019 07:50 AM
silence2-38554
98
09-21-2016 02:52 PM
polotska
08-23-2015 09:10 AM
Getrieben
08-15-2015 09:09 PM
Quick Reply: R56 Carbon Cleaning - BG Fuel Air Induction Cleaning Service
