Drivetrain "rebuilding" the engine
Old 01-11-2013, 11:19 AM
mgrant's Avatar
mgrant
mgrant is offline
Hey all
So recently my 2005 R53 badly overheated and now it wont start. We checked the oil and there seemed to be water in the oil. So my guess was that my head gasket ahd cracked/failed.
Now since i am planning on changing the gasket and having the engine completely apart i was thinking of changing other parts for preventive/performance measures
Here are the parts
  • Head gasket
  • New head bolts
  • Water pump + oring
  • Intake manifold gasket
  • Oil filter Housing to Block Gasket
  • Timing chain guides
  • Timing chain tensioner
  • Valve seals
  • Silicone radiator houses
  • new supercharger oil
  • RMW street camshaft
Was also thinking of having my head ported/polished a bit.
So my question was ... am i missing anything ?
Also would i need to buy larger injectors or am i still ok with the stock 340cc ?
thx in advance
Old 01-11-2013, 11:40 AM
Braminator's Avatar
Braminator
Braminator is offline
unless you do an ECU custom tune, yes you are fine. IF you are planning a tune then get 380cc injectors. Do you have a smaller pulley? 1 step colder plugs? Thermostat?
Old 01-11-2013, 12:50 PM
martinb's Avatar
martinb
martinb is offline
Just curious.....are JCW plugs a step colder than regular S plugs?
Old 01-11-2013, 01:04 PM
Braminator's Avatar
Braminator
Yes.
Old 01-11-2013, 04:03 PM
martinb's Avatar
martinb
martinb is offline
Thanks! 'Makes sense with more heat being generated in the combustion chambers.
Old 01-11-2013, 05:27 PM
ColinGreene's Avatar
ColinGreene
ColinGreene is offline
yeah should be good to go just like that
find out why you over heated it and fix that as well.
Old 01-12-2013, 01:04 AM
BlwnAway's Avatar
BlwnAway
BlwnAway is online now
Stay away from the silicone radiator hoses, there has been issues with degridation & collapse.
And you really won't "need" the intake gasket, (unless it shows signs of problems from the overheating) copper spray gasket works just fine in most instances.
Old 01-12-2013, 06:41 AM
Braminator's Avatar
Braminator
???? I have had my Samco hoses installed for 2 years with no issues.
To save couple bucks, just replace it IMO.
Old 01-12-2013, 09:11 AM
BlwnAway's Avatar
BlwnAway
I can't find it now but I remember a thread involving some people that were having troubles with silicone hoses weakening , don't remember if it was from heat or the chemical compound of the antifreeze, but it was coolant hoses.
Same thing with the metal gaskets, just thinking about saving the OP a couple bucks, I've only ever sprayed my metal gaskets & have had "0" leaks.
I think the money would be better spent on injectors, esp. if you're going to do a port-n-polish, don't forget, that's all a JCW setup is, as far as the head goes, mildly ported & slightly more open exhaust, and only a -13% pulley for boost.
Old 01-12-2013, 09:56 AM
mgrant's Avatar
mgrant
mgrant is offline
copper spray ??? never heard of it
BTW i currently have a CAI, exhaust and 17% pulley
Was planning on doing injectors and tune but that will be a bit later down the road (probably sometime this summer)
Also will I need to resurface both the head and the block to assure a proper fit ?
Old 01-12-2013, 10:06 AM
Braminator's Avatar
Braminator
Old 01-12-2013, 10:13 AM
BlwnAway's Avatar
BlwnAway
Yup, use it on all my metal gaskets, except exhaust, makes a really good seal and holds up to the heat, as long as the gasket itself is in good shape of course. I've even seen it used on new head gaskets in racing applications.
Old 01-12-2013, 10:54 AM
mgrant's Avatar
mgrant
mgrant is offline
im guessing spraying a new gasket would help it with high temp even when its not for racing
will give it a try for sure.
Could probably save me the time to have the block and head resurfaced since it would seal all the imperfections
Old 01-12-2013, 11:16 AM
BlwnAway's Avatar
BlwnAway
If you overheated as bad as you say, still have it checked, on a head gasket the spray only really works as an extra seal for something that is already 100%, not as a fix, it will "help" on the lesser sensitive items though.
Old 01-16-2013, 05:40 PM
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
ClintTheMiniOwner is offline
I have my mini apart right now to change pistons and do head touch up. I didnt have to take the engine completely out which was nice but the gaskets all come in a set so you will get all the gaskets anyways. Check out thumper heads and revolution heads. Thumper has a few options to look at. Maybe you can work out a deal on a good core w the vender if yours is cracked... The rocker assembly is touchy on these heads so you want a mini experienced machinist to do it. Trust me I have had my head off 4 times. Also get ARP head bolts in case you have to take it off again! it will pay off since you can use them multiple times.
Old 01-16-2013, 06:31 PM
ColinGreene
Why would you recommend a thumper head?
and whats difficult about the rocker arms.
Why all this work if your just going to sell it.
Old 01-16-2013, 07:18 PM
JCWSLAYER's Avatar
JCWSLAYER
JCWSLAYER is offline
You have many choices for heads and I would say research and make your own decisions.
Old 01-16-2013, 09:34 PM
ClintTheMiniOwner
Wow Collin, your tough. I have talked to people who build the heads. I recommend that you talk to them also. I remember myself, the plastic little rocker end cap retainers are ready to fall out when you disassemble and I know that the valve hight is important when doing the install cause the rocker arms will destroy the tops of the valves or you could have a loud cold starter if the valves are set too low. I have seen both. I just think one should trust a mini machinist, especially talk to one
RMW - biggest valves
Thumper- offers stock size valves if thats your budget. Also makes a large valve head (havent seen it)
This next post looks like a good option
looks good! \/
Old 01-17-2013, 04:04 AM
Braminator's Avatar
Braminator
Old 01-18-2013, 01:06 AM
ColinGreene
Clint, its Colin, and why am I tough? Don't know, could just be my personality.
You had your head ported by a local guy right? what happened with that.
I don't see the point in putting a head on with stock valves i guess is my point.
If you were going to do it, i would go full tilt and not have to decide to go back in there and do it again.
Also i feel like you could say I am a mini specialist.
Anyway the Rocker caps should not fall off at all under any circumstance if they are falling off you need new ones.
You know when they are new they are a bright yellow/green.
Personally i have not seen one with a valve height too low but like anything wonders will never cease.
Old 01-18-2013, 01:23 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
am i missing something here? OP says he found water/antifreeze in the oil ...
i see no mention of at least looking at the rod big end and crank main bearings?
and what about checking the piston to cylinder fit, ring fit in the piston lands, the ring end gap, wrist pin to rod and wrist pin to piston?
no sense at all putting a new head on a bottom end ready to grenade
scott
Old 01-18-2013, 04:30 AM
BlwnAway's Avatar
BlwnAway
Historicly with the motors in the R53's unless it was driven for a long time with the coolant in the oil, the bottom ends have been just fine, (of course "if" the original problem wasn't in the bottom end) and it has been OK to just rebuild everything up top.
Plus most if not all of the average "needed" bottom end repairs from something like this, can be done from the bottom, without taking the top apart again, if the lack of lubrication from the contaminated oil, did do some lower end damage.
One of the great things about full synthetic oils is that they hold there properties far better than natural oils in these situations.
Old 01-18-2013, 06:52 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
thanks for the reply and clarification
if it was my car, i would have to look at a minimum of 1 piston
i have seen what happens to the piston ring lands when coolant gets in the oil and is subjected to the environment of the piston ring land
also, removing a piston would allow looking at a rod big end bearing
maybe i am being too old school
scott
Old 01-18-2013, 07:18 AM
BlwnAway's Avatar
BlwnAway
Not really, but the real difference here is the synthetic motor oils and how much better protection they offer.
Basicly with the head off you can do a general "look see" of the condition of the cylinders anyway, and since everything else can be done from underneath, after the fact, as long as there wasn't an evident problem in the bottom, you're not out that much to give it a try, as long as you pay close attention to things once it's back running again.
Old 01-18-2013, 05:26 PM
ClintTheMiniOwner
Collin, I had issues with the mini mania oversized valves. Checked out everything and ended up using valve lash caps and setting the hight lower on the intake and a little higher on the exhaust. I wish I had 2 grand for a good head plus my head is ported pretty good so I doubt it would make it as a core. I replaced the plastic valve lash caps on the rocker.
With 2 guys we had the head off in an evening and the oil pan off the next evening.
Installing the wiseco 8.5 tonight. Im going to keep the car.
Quick Reply: Drivetrain "rebuilding" the engine
