R50/53 PLEASE HELP 06 mini wont start after battery disconnect!
Old 06-22-2013, 06:36 PM
WizardEyes's Avatar
WizardEyes
WizardEyes is offline
Had battery disconnected for hour or so, dealing with some stuff under the dash, reconnected the battery and NO START. i have mini alarm on it could it have something to do with that? need help soon as this is my only car and i work tomorrow!
Old 06-22-2013, 06:38 PM
WizardEyes's Avatar
WizardEyes
some more info, when i open the doors all the light come on as should along with alarm beeps when i lock and unlock, but when i stick the key in the ignition NOTHING when i turn over not only does the car NOT START but none of the gauges pop up. the Odomitor only lights up when i push odometer reset button in
Old 06-22-2013, 08:59 PM
EHans's Avatar
EHans
EHans is offline
Check fuses first.
Old 06-22-2013, 09:53 PM
dannyhavok's Avatar
dannyhavok
dannyhavok is offline
Make sure you didn't put the non conductive washer in the wrong position when reconnecting the battery... I did that, and it was a very embarrassing trip to the dealer. I was getting a little power (lights may or may not come on, etc.) but not enough to try to start or turn the radio on.
Old 06-23-2013, 08:17 PM
LLZuB's Avatar
LLZuB
LLZuB is offline
Clean the terminal with sandpaper...Garuntee it will work and it's probably calcium built up. My car all of a sudden wouldn't start a couple weeks ago...went out and bought a new battery and still wouldn't start....cleaner the terminals and it started up right away.
Old 06-29-2013, 10:51 PM
joylove's Avatar
joylove
joylove is offline
Go over the modifications with a fine toothed comb.
Old 06-30-2013, 02:15 AM
freestylebiker33's Avatar
freestylebiker33
freestylebiker33 is offline
sometimes when you disconnect the battery the alarm gets activated, plug the battery in close all the doors and (insert) the key in the door and lock and unlock the car , sometimes that will reset the alarm.. hey worth a try.. i have seen this work on several cars
Getrieben
11-19-2020 06:03 PM
mdutton11
14
10-26-2015 01:47 PM
Lt. Dan
08-10-2015 12:46 PM
bc219
08-10-2015 11:22 AM
nismo4life
08-05-2015 08:31 AM
Quick Reply: R50/53 PLEASE HELP 06 mini wont start after battery disconnect!
