Drivetrain Standard motor 380CC injectors
Old 09-27-2013, 08:54 AM
Manny_cooper's Avatar
Manny_cooper
Manny_cooper is offline
Y'all are so frikin bright! Lol....still waiting for my injectors. I will leave feedback once I get and install them.
  #152
Old 09-28-2013, 08:34 AM
TheBigChill's Avatar
TheBigChill
TheBigChill is offline
Once you get them, let us know the part # listed on the side. It should be 0280158096. As of right now, that is the best JCW 380 alternative for our cars. Stay tuned, as I've got a good line on several sets and will sell them to anyone interested at cost.
  #153
Old 09-30-2013, 05:34 AM
ignitionmodule's Avatar
ignitionmodule
ignitionmodule is offline
Incidentally, the new production method we're implementing for the old style EV1-EV3 injectors will allow production of the DEKA 1D short injector as well. Unfortunately, production will likely be over a year from now as we get in mfg equipment and parts converted over. Once we get to that point, any aftermarket company will be able to place a custom order for any flow/spray pattern that can be produced.
  #154
Old 09-30-2013, 07:37 AM
Raven Mocker's Avatar
Raven Mocker
Raven Mocker is offline
So then in about a year we should have better product thats going to give us proper, if not high quality spray, and be more tune friendly for our R53's?
  #155
Old 09-30-2013, 08:33 AM
TheBigChill
^ Those things already exist. You just have to be willing to step outside your comfort range, and try something that isn't sold by a MINI vendor with a made-up name and scratched off part numbers.
Regarding body size comparisons between our Siemens Deka units and "standard" body EV14's: The base and JCW R53 injectors are 68mm total and about 54mm between O-rings. EV14 standard length is 65mm overall, and 49mm between O-rings. Our Siemens Deka units are larger in every respect when compared to standard sized EV14 unit.
  #156
Old 09-30-2013, 08:52 AM
Manny_cooper
http://www.ebay.com/itm/FORD-FOCUS-ST-225-2-5-INJECTOR-RAIL-PRESSURE-SENSOR-INJECTORS-/111158298205?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19e18d065d
Whoever wants to chime in and experiment, go ahead. Just sharing with all of you.
  #157
Old 09-30-2013, 09:28 AM
vietnameeh's Avatar
vietnameeh
vietnameeh is offline
Or you can put your injectors in and chime in
  #158
Old 09-30-2013, 09:52 AM
Manny_cooper
I will, they will get here wednesday and the plug converters on thursday. Gotta wait my friend. I'm surprised not many have taken the initiative lol. Anyways I will take pics and post them here once installed.
  #159
Old 09-30-2013, 10:10 AM
ignitionmodule
Mostly true but most people are reluctant to do this.
There's a British company out there making adapters and o-ring spacers for injector applications, but our marketing department takes a pretty hard line about "OE appearance" which is why we don't put things in the box that work but don't look the same. They have to "look" like the OE part as well.
My point from above is we will be able to produce the Deka D1 short outline in about a year, but it will be based (internally) on our G injector design. From just a consumer repair standpoint, this is a good project because we currently buy the injector from Delphi. For the performance market, a vendor would have to request a specific flow and spray pattern and we be able to produce to order, likely in a different color just to keep parts separate.
To your point about using taller injectors, I completely agree provided there's clearance under the hood and proper spacers are fabricated. Personally I'd rather see the entire rail on spacers rather than injector cup spacers. That just adds another possible leak path.
  #160
Old 09-30-2013, 10:14 AM
ignitionmodule
Technically yes. I plan on matching the OE flows and spray patterns, but the tuner version would have to be special ordered by a perfomance company.
  #161
Old 09-30-2013, 10:39 AM
TheBigChill
Agreed; having the rail on spacers is preferred for taller injectors, reducing the likelihood of leaks compared to using cups on the tips. Also, when you use cups, you change the area which the injector will actually effectively spray by backing the injector tip out of the manifold. Usually negligible, but worth noting.
Maybe I misread somewhere, but my point is that Bosch EV14's in standard length are actually shorter overall than our current OEM injectors. They mount perfectly fine, and only need special attention when using USCAR to Jetronic adapters (intercooler interferes with adapter).
I suppose that my point is this: I believe our fuel rail and manifold can accept any Bosch EV6 and EV14 injector in standard size, and not require cups, spacers, or "anti-spacers". I believe anything in "long" form will require rail spacers, and anything in "short" form will require different hardware to secure the fuel rail.
Again, forgive the rambling if I get off-topic. I just want to continually add info to this thread, as I plan on writing an R53 injector manifesto :0)
  #162
Old 09-30-2013, 02:29 PM
ignitionmodule
Originally Posted by dhabutcher
Got my JCW injectors out at lunch, Both set boxed up ready to ship
I haven't done much research on injectors until last night I found some intresting options. I was a Tech at a GM dealer for 4 years I should had been looking then
USPS. 9114901159818153169242
These are in the lab. Should get them back in a few days with data.
The flow curve, btw, is constructed but you have to know the dynamic flow in order to do it.
  #163
Old 10-01-2013, 01:44 PM
ignitionmodule
Gen 1 Cooper and JCW injector flow data
Just the flow at the moment. Our tech left off the spray pattern.
I'll have to get the admin to post the Excel file if anyone wants it over the pdf. Probably wait until the spray pattern data to consolidate into 1 file.
All values are grams/min heptane.
File Type: pdf
  #164
Old 10-01-2013, 07:58 PM
TheBigChill
Right on. Thanks for doing that, it's much appreciated.
For those who rather avoid the math, results as follows, converted to cc/min.
JCW 380cc @ 3 bar: 371cc
JCW 380cc @ 3.5 bar: 399cc
Base R53 330cc @ 3 bar: 347cc
Base R53 330cc @ 3.5 bar: 373cc
At this point, two things are clear. 1) As suspected, like essentially all other injectors out there, ours also got their names based on their static flow rates at 3bar, not 3.5. This is industry standard, and helps us shop for alternatives with more certainty. 2) The common term "330cc" used to describe base R53 injectors is quite a bit off. The test performed here also matches WitchHunter's actual flow data, which states that our base R53 injectors actually flow 348cc @ 3 bar, not 330. They were right.
I stand by my recommendation that Genesis 380cc, and Bosch Part# 0280158096, are the best alternatives to pricey JCW 380cc units. This is based on their impedance, flow rating, body size, spray pattern, and modern build and operating characteristics. I can provide a list of cars that the above Bosch part is found in, should anyone be interested. I will be running these in my car next week.
Thanks again, Ignition. We know for a fact that the factory spray pattern is twin beam, but whether it's 15 or 20 degree is yet to be seen.
  #165
Old 10-02-2013, 05:08 AM
ignitionmodule
I'll probably have spray by the end of the day, cone angle, separation angle and orientation.
When we commonize parts here for the aftermarket, we can get away with a narrower rather than a wider cone. Widening the cone without changing the fuel map (or intake runner geometry for that matter) usually results in wall wetting, which is bad.
On flow variation, you should expect no more than +/- 5%. Injectors with a lot of mileage might be outside that range.
Also, now that you have the dynamic flow, you can build the real flow curve. I will try to get to that this morning to see if there's a response difference beteen these two injectors.
  #166
Old 10-02-2013, 05:53 AM
TheBigChill
Absolutley.
If you deviate too far from the original cone and separation angle, you can start having idle and tuning issues due to fuel being sprayed on the manifold port's central bridge or "exterior" walls. Though this is mainly an issue when poor atomization is also present with the extreme change in cone/separation angle. There are some vehicles out there who use multi-port heads, but from the factory run injectors which use a very wide, single cone w/ great atomization. These spray a bit of fuel on the central bridge, but with the large majority of fuel being well atomized and distributed well over the intake valves, tuning, idle, and AFR stability is not an issue.
I'm still very interested to see the spray pattern analysis of our OEM injectors.
  #167
Old 10-02-2013, 03:50 PM
Manny_cooper
Fuel Injectors 0280158096
Hey guys,
Got the fuel injectors today. Thought I might post some pics so you can have a better look at them. Anyways, I will have an extra one laying around if you decide to run some tests. I'm getting them cleaned at a local recommended shop. Hopefully by this weekend I can say if they work or not. I'm still waiting for the connector adapters.
Manny
Attached Thumbnails Standard motor 380CC injectors-20131002_174008.jpg   Standard motor 380CC injectors-20131002_173834.jpg
  #168
Old 10-02-2013, 07:58 PM
vietnameeh's Avatar
vietnameeh
i dont know much but i wanted to say i notice the tops dont have o rings?
  #169
Old 10-03-2013, 05:25 AM
TheBigChill
Those are the correct injectors
Yes, the tops need O-rings. They're so cheap, don't reuse your stock ones unless they're in great shape. Also, seeing as though you'll likely be using the adapters that I recommended, you're going to have slight clearance issues with the intercooler mounting after the injectors are installed. Talk to Vietnameeh about what he did to give a bit more room; I believe a couple small washers do the trick just fine. To avoid the interference, you can use a different type of harness adapter. Instead of a one-piece, they sell two piece units with a small section of wire in between the two connectors.
Like these:
  #170
Old 10-03-2013, 06:20 AM
ignitionmodule
Spray pattern
Injector sprays done. Lab says the JCW may actually be a cone rather than twin spray.
Attached Thumbnails Standard motor 380CC injectors-0391511-spray.jpg   Standard motor 380CC injectors-1521390-spray.jpg
  #171
Old 10-03-2013, 08:50 AM
Manny_cooper
Like these:
Ohh yeah I have the O-rings, I took em out to verify they were not dryrotten or bad, seem to be good. I'll have to use some washers because I got the one-piece adapters, no biggie. Thanks!
  #172
Old 10-03-2013, 08:52 AM
TheBigChill
Very interesting. Not quite sure what to make of the graphs, honestly. When we say "15 or 20 degree spray pattern", we're talking about the angle which exists between the two interior limits of the spray beams. Viewing the Mynes video below, the 15 or 20 degree angle looks to be accurate, by rough eyeball.
For reference:
Mynes Tuning did bench flow testing that clearly displayed twin beams spray. This video is on YouTube, and tested Siemens 330cc, Siemens 380cc, Bosch 550cc, and Bosch 440cc:
  #173
Old 10-03-2013, 10:34 AM
ignitionmodule
That's about what we saw. Our gas building, where we keep the explodey stuff, has a fairly accurate, though older analog system consisting of progressively larger annular rings that sit under the injector and collect the heptane. The graph is a representation of where all the fluid landed.
The tech's data showed a 19 degree separation (so 20 degrees) and what we would probably call a pair of 10-12 degree cones. The JCW injectors had a "bushier" spray. Probably just the larger flow and possibly high mileage injectors.
FWIW, the more modern spray pattern analysis machines are similar to ours, they just have a larger number of collection pockets laid out in a grid. The injector is mounted a fixed distance above and results in a 2-D picture of where everything lands.
  #174
Old 10-03-2013, 10:42 AM
TheBigChill
Fantastic info. Thanks for clarifying the angle of deviation.
  #175
Old 10-03-2013, 11:16 AM
vietnameeh's Avatar
vietnameeh
i wish i had used the 2 piece adapters but no biggie lollooks like it would provide really good clearance
Quick Reply: Drivetrain Standard motor 380CC injectors
