Drivetrain Borla Agressive exhaust questions
Old 11-17-2013, 04:47 PM
ti22fjc's Avatar
ti22fjc
ti22fjc is offline
Just wanted to know if anyone had and their thoughts. I know they are insanely expensive, but the SS construction will help in WI winters.
I would also like to keep, if not, increase the pop and burble noise-which is my favorite feature of my R53, and want to know if it increases or will I loose.
Old 11-17-2013, 05:04 PM
ACallahan's Avatar
ACallahan
ACallahan is offline
You will not look back, Borla systems are quality but you pay for that as well. Check youtube out for plenty of Clips of R53 w/borla.
Here is one:
Cease's Avatar
Cease
Cease is offline
I just installed the Borla street exhaust. Very well made system, I asked my exhaust shop to weld it all in instead of using the clamps provided.
The street exhaust is about as loud as the one-ball mod and about the same burble-pop. It's exactly what I wanted, deeper growl, some pops but no drone on the highway. I can barely hear the exhaust under 3k with the windows up. Don't have hp numbers but the butt-dyno notices a slight gain.
Old 11-18-2013, 04:57 AM
rwkeating's Avatar
rwkeating
rwkeating is offline
Here is a great video about both the Borla exhausts for the R53 with dyno results and sound clips:
Old 11-24-2013, 11:56 AM
sssevita's Avatar
sssevita
sssevita is offline
Borla Agressive Exhaust
I have the Borla agressive exhaust on my '03 MCS with the stock header / cat. It is louder than the JCW exhaust my car previously had and also has no highway drone. In the future I may remove the resonator and install a straight pipe in its place to make it a little louder.
Old 11-24-2013, 12:03 PM
ti22fjc's Avatar
ti22fjc
ti22fjc is offline
That's great!! I JUST ordered the Borla aggressive. Had to confirm shipping address, if I ship home, wife would put me in a body bag.
Old 11-24-2013, 12:17 PM
spr061's Avatar
spr061
spr061 is offline
I drive a base model r50 ... Would an aftermarket exhaust make a big difference?
Sent from my iPad using NAMotoring
Old 11-24-2013, 12:30 PM
ti22fjc's Avatar
ti22fjc
ti22fjc is offline
Originally Posted by spr061
I drive a base model r50 ... Would an aftermarket exhaust make a big difference? Sent from my iPad using NAMotoring
I have read that any exhaust does after a bit of tuning. I have a KN air filter, so I'm not sure how much of a difference I would feel. Summit racing had a Borla for a Cooper, and what I thought was very reasonable.
Old 11-24-2013, 12:55 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
The Borla Exhausts don't sound bad, I've only had a few complain of drone with them on an R53. But I don't recommend them do to the failures I've seen with them. As you may have seen these have several joints to bolt together. While those joints make it easy to adjust they will all end up leaking, and the welds on the Borlas will all crack over time as every borla I've seen come in on an R53 was cracked and leaking.
I'd suggest the Stratmosphere Catback or Milltek. These have proven to be the most reliable over the years and make the most torque. With only 3 joints the potential for failure also reduces. And the pop and burble will be slightly amplified, but not too much where it is annoying. FYI they both cost less than the Borla.
Old 11-24-2013, 01:14 PM
ti22fjc's Avatar
ti22fjc
ti22fjc is offline
Originally Posted by WayMotorWorks
The Borla Exhausts don't sound bad, I've only had a few complain of drone with them on an R53. But I don't recommend them do to the failures I've seen with them. As you may have seen these have several joints to bolt together. While those joints make it easy to adjust they will all end up leaking, and the welds on the Borlas will all crack over time as every borla I've seen come in on an R53 was cracked and leaking. I'd suggest the Stratmosphere Catback or Milltek. These have proven to be the most reliable over the years and make the most torque. With only 3 joints the potential for failure also reduces. And the pop and burble will be slightly amplified, but not too much where it is annoying. FYI they both cost less than the Borla.
Dang!!! Too late and the Borla just shipped... :(
The SS construction was a big plus, especially in WI winters. Wouldn't the issues fall under warranty??
Old 11-24-2013, 01:26 PM
WayMotorWorks
Vendor
I've had them warranty them out, but you have to jump through the hoops and pay return shipping on the old exhaust for them to inspect it before they send you a new one. Not worth the time. Kinda like that commercial is the car reliable or the warranty???
Old 11-24-2013, 01:33 PM
ti22fjc's Avatar
ti22fjc
ti22fjc is offline
I will see what I can do the Milltek w/o resonator was one I did look at, too.
Maybe I should just get an intake!
Drivetrain Products
08-21-2015 10:36 AM
WestfaliaR
08-19-2015 08:01 AM
elightbo
08-17-2015 01:50 PM
massmini03
08-12-2015 11:19 AM
papawhiskey
08-10-2015 09:31 PM
Quick Reply: Drivetrain Borla Agressive exhaust questions
