Service Engine Soon light - what does it mean?
Old 01-27-2006, 06:59 AM
Shea's Avatar
Shea
Shea is offline
Hey folks,
I was starting the car this morning and the Service Engine Soon light came on and stay lit. Car's running fine, and I'm still 5k miles to the next suggested service. Shutdown and restart and the light's still there (sounds like a PC doesn't it??) Anybody know what they light is for?
Thanks in advance.
Old 01-27-2006, 07:02 AM
mdsbrain's Avatar
mdsbrain
mdsbrain is offline
Could be any number of things. Maybe have your local AutoZone check the code for you or your local dealer. Also double-check your gas cap is on right
Old 01-27-2006, 09:31 AM
beken's Avatar
beken
beken is offline
I vote for the gas cap check first. If that doesn't solve it, find out the problem code.
Old 01-27-2006, 10:16 AM
fred3's Avatar
fred3
fred3 is offline
As strange as it may seem(harmless sarcasm)...
Originally Posted by Shea
Hey folks,
Thanks in advance.
your owners manual has the answer. All you have to do is read it. I know that's a lot to ask(more harmless sarcasm), but there you have the easiest answer/solution.
Old 01-27-2006, 11:04 AM
kenchan's Avatar
kenchan
kenchan is offline
doubtful.
as above SES can be triggered by MANY different parameters.
i would also suggest taking it into Autozone and get the code read. they can tell you what triggered it. (i have my own OBDII reader and can clear it at home).
why don't you use your computer that your on and search what DTC's and SES is all about? (inside joke for FL tolls)
Old 01-30-2006, 06:25 AM
Shea's Avatar
Shea
Shea is offline
Well the gas cap didn't seem make a difference. As some of you might seen before the SES light goes off on it's own with nothing done to it. It doesn't bother me but I just want to know what happened.....once again, thank you guys for helping out.
Old 01-30-2006, 06:48 AM
danmcg's Avatar
danmcg
danmcg is offline
Mine was the knock sensor on a '05 MCS. Took it into the dealer and it was a 4 hour job! (albeit free)
Old 01-30-2006, 10:23 PM
LombardStreet's Avatar
LombardStreet
LombardStreet is offline
Moderator
Could be a zillion different things. Mine was a "burned out wheel sensor." (Service Advisor's words.)
As my Service Advisor explained to me, what the SES light really means is that something has raised a flag and the computer is signalling that you need to bring the car in to the dealer.
Old 01-30-2006, 11:04 PM
Motor On's Avatar
Motor On
Motor On is offline
Even if your light shut-off, wouldn't hurt to check all fluid levels, caps tight, air filter clean and hose connections, then if it turns on again go to your local AutoZone get the code and find out what triggered the light to go off in the first place.
Old 02-01-2006, 04:39 PM
ski's Avatar
ski
ski is offline
Mini has a fix for the service light. I got it and it has never come back on again. ski
Old 11-24-2013, 12:46 PM
Ming Brookside's Avatar
Ming Brookside
Ming Brookside is offline
I tried going to AutoZone and they don't have a read out code for Mini's or Beamers..
Old 11-24-2013, 01:06 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Wow, nothing like reviving a generic thread that's 7 years old.
They can read it, you might not get some of the specific codes, but they should have at least tried.
Old 05-17-2016, 11:36 AM
dcbritboy's Avatar
dcbritboy
dcbritboy is offline
OK, so my "Service Engine Soon" light came on recently. I tried the gas cap tightening suggestion. It turned off. A few miles down the road it came on again. I had a recall/service schedule (2005 model) so waited until I took it in, however the light turned off (again) before I went in. They did a whole service and (I believe) diagnostic and nothing came up. That was about a month ago and suddenly the morning the light came on again. I have some repairs/maintenance scheduled for end of July (gasket value leak and the right side the axles). The car is driving fine, no difference in feel/sounds.
Any thoughts?
Old 05-17-2016, 12:26 PM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Any thoughts?
Typically, a CEL will store the code until it is cleared. Since it is on now, I'd suggest bringing it by to a local MINI indy shop or dealer to see if they can pull the code while the symptom is present.
888.280.7799 | 6am - 5pm PST
Old 05-18-2016, 11:42 AM
dcbritboy's Avatar
dcbritboy
Thanks. Am taking it to my local shop to read the codes and see whats up! They didn't made it sound like it just might be an old code that needs to be cleared. Hopefully it is as simple as that
Old 05-23-2016, 03:17 PM
Capt_bj's Avatar
Capt_bj
Capt_bj is offline
MOST codes are a result of an out of range number for the emissions control system ... an oxy sensor or something like that.
I had the light on and off for years .... wet and cold in the AM the light would be on ... drive 30 miles (and heat up the motor) light off . . .
I don't say ignore it ... but don't loose sleep over it . . .
Old 05-23-2016, 03:24 PM
dcbritboy's Avatar
dcbritboy
Thanks. I did take the car in and they read the code. They said it was actually a current common problem with a car of this age. It the measuring the difference (I think) between the fore and aft O2 sensors (or something). The code was showing that there was a difference between the two, but it was coming from the back one, so could be cleared (which they did) and to just watch it.
Thanks all!
Old 05-26-2016, 04:49 PM
otfox's Avatar
otfox
otfox is offline
Good, hopefully it's the O2 sensor and not the cat.
Old 01-04-2017, 12:52 PM
lhowlett's Avatar
lhowlett
lhowlett is offline
stripped gas cap?
My 'Service Engine Light' just came on and I checked the gas cap. I had noticed that I could usually turn the cap to the right and hear around 4 clicks to close it. Now it only clicks once and is too easy to unscrew. I plan to swing by my Mini garage but I wonder if this has happened to anyone else -- a 'somewhat' stripped gas cap after 14 years wouldn't sound strange to me.
Old 01-29-2017, 09:17 PM
ptkacik's Avatar
ptkacik
ptkacik is offline
Wait what??? Since when is "SERVICE ENGINE SOON" the same as "CHECK ENGINE"?
I thought check engine threw codes related to emissions and service engine soon meant you were due for service.
Please clarify. Isn't check engine a special yellow engine light regulated by the government and tied to the OBDII system?
Peter
Old 01-29-2017, 09:53 PM
lhowlett's Avatar
lhowlett
lhowlett is offline
Took my Mini in and they ran the computer check. It was an emissions problem. Not dangerous to drive but they ordered the part and replaced the old one. No problems since then. It wasn't the gas cap. (Obviously.)
Old 02-01-2017, 09:01 AM
PelicanParts.com
Vendor
Peter
Post #12 here (just the first sentence): https://www.northamericanmotoring.co...ml#post3648107.
09R56
11-16-2022 10:49 AM
W0TM8
12-19-2019 07:50 AM
oldkid6
08-11-2015 08:13 PM
08-07-2015 08:02 AM
Quick Reply: Service Engine Soon light - what does it mean?
